Honda Manual Transmission Fluid
Old 10-15-2002, 03:25 AM
Red Ride's Avatar
Default Honda Manual Transmission Fluid
I took my 94 Del Sol into the Honda Dealer yesterday and had the transmission fluid changed. The reciept says they used 10w30 motor oil. Is this Normal??? Is this the same as the Honda Manual Transmission Fluid???? Should I take it back and say to put the right stuff in there???
Old 10-15-2002, 03:35 AM
dirtySOHC's's Avatar
Default Re: Honda Manual Transmission Fluid (Red Ride)
maybe it was misprinted and they acutally used the HMTF or they simply just used the 10w30. it is in most cases ok to use that oil.
Old 10-15-2002, 03:55 AM
97hb's Avatar
Whenever I go to the dealer and ask for mtl, they always ask me what year car I have. I asked them once and they said its because only the newer trannys use the mtl, but who knows.
Old 10-15-2002, 04:38 AM
BERT-O's Avatar
I think they screwed you over. Kinda the same thing but doesn't have all the additives like the Manual Transmission Fluid (MTF). Such as keeping all the bearing quiet and protection.
The part number should have been #08798-9016. Should have been billed for 3 quarts.
Retail for $4.43.
I would suggest to go back and tell them why they used motor oil. A big differences among the two.
And "No", its not normal for them to used 10w30 motor oil. Especially for a dealer who gets tons of this stuff at dirt cost.
=bert
Old 10-15-2002, 04:42 AM
BERT-O's Avatar
Default Re: Honda Manual Transmission Fluid (97hb)
From '86 till present. What the hell they ask you that?
Some dealership are ripoff, and its sad.
Old 10-15-2002, 05:29 AM
New User
Kalokohan's Avatar
I just received mt HMTF from AH Motors a couple days ago. This will be the first time I change my tranny fluid on my 1.8. It doesn't look that difficult. I'm guessing my c1 has about 25K miles on it, did I wait too long?
Old 10-15-2002, 06:08 AM
JSPEEDNC's Avatar
Default Re: Honda Manual Transmission Fluid (Kalokohan)
The Honda MTF is far superior to the 10w30, try adding some lucas additive for some additional protection...
Old 10-15-2002, 07:45 AM
lagger's Avatar
10w-30 can be used, but it's suggested that you only use it long enough to get the correct fluid (Honda MTF)
Old 10-15-2002, 08:04 AM
buzlink's Avatar
Honda owners manual recommends putting in oil if your changing it.
Its funny that the dealer ship put it in though.
I used AMSoil 10W30 synthetic last spring when I changed my transmission fluid (oil).
[Modified by buzlink, 11:05 AM 10/15/2002]
Old 10-15-2002, 08:14 AM
Blue-Civic-Hybrid's Avatar
Default Re: Honda Manual Transmission Fluid (buzlink)
I know Honda MTF works better than regular 10w30..I know because when i was repairing the axles on my brothers CRX, we had to drain the tranny fluid to take out the axles, and we replaced it with 10w30 motor oil from pennzoil. I didn't tell my brother this, and immediately as he drove it, he complained about the tranny being not as smooth, so i drove it also..and yes..Honda MTF makes a difference
I use Honda MTF only on both of my cars.
Old 10-15-2002, 08:55 AM
Z4xLSVTEC's Avatar
Default Re: Honda Manual Transmission Fluid (Blue-Civic-Hybrid)
10W-30 is fine. Straight 30 is better. Honda MTF is the best. Especially run the HMTF if your tranny is making noise. Believe it or not, you can also run 1qt of ATF and the rest 10W-30. My friend is a tech at Acura and this is what they do with the GSR tranny's which make noise. In fact, this is what I am running now, since I didn't have any HMTF.
Old 10-16-2002, 08:19 AM
Red Ride's Avatar
Default Re: Honda Manual Transmission Fluid (Z4xLSVTEC)
Yea, I called and spoke with the dealership Service Rep and said wtf??? I asked how come they didn't use the HMTF? He said that the 10w30 was fine, and that was what they use when they do Tranny Drain Service Special.
I know better know to INSIST that they use the HMTF, it only would have cost about $5.00 more....... Live and learn.......
Old 04-16-2005, 07:59 AM
Fuster_Cluck's Avatar
Default Re: Honda Manual Transmission Fluid (BERT-O)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BERT-O &raquo;</TD></TR><TR><TD CLASS="quote">
Retail for $4.43.
What I've been searching for Now time to bargain at the local Honda dealers
Old 04-16-2005, 08:04 AM
a1320honda's Avatar
Default Re: Honda Manual Transmission Fluid (Hybrid93Hatch)
from experience, ive used plain 10w30, honda MTF, and GM synchromesh. honestly i will never use anything other than gm stuff. its like gold man, do a search on here for synchromesh. just my two cents
Old 04-16-2005, 08:57 AM
mightyjoecivic's Avatar
I also heard of using penzoil synchro mesh additive, from what i heard its the fountain of youth for manual trannys.
Old 04-16-2005, 09:00 AM
Luserkid's Avatar
Default Re: (mightyjoecivic)
Alot of shops do that where they put engine oil in the tranny, stupid but it works until you grind.
jonnybadboi9
06-10-2016 02:56 PM
dlstech
03-26-2012 07:38 PM
TOO MUCH TORQUE
24
09-02-2011 06:24 PM
TWSS-EF9
14
05-31-2011 12:58 PM
stealthteg
07-25-2002 01:20 PM
Quick Reply: Honda Manual Transmission Fluid
