Rear drum and rotor, wheel bearing are they same?
Hello
i can`t find any info about this..
are they same?
I did rear Drum to Rotor conversion on my 96 hatch.. and wheel bearings needs to be changed
i have wheel bearing in good condition from my drum brakes...
an i need to change wheel bearing on my rear rotor brakes...
can i use wheel bearing and assembly hub from my old drum brake?
Sorry again for my English....
are they same?
I will answer to my question :D
So today i was bored and went to my garage ...
compared rotor hub and drum hub and whoalaaa
they are exactly same...
except drum hub did not have holes for rotor mounts/screws... but its fine works good without it ...
already installed it and works just fine ....
they are exactly same... except drum hub did not have holes for rotor mounts/screws... but its fine works good without it ...
The offset is different. The bearing for the rear drum either puts the face of the hub in or out a little further, I can't remember which way it went. But I do remember comparing them and they are different. It's also the reason guys used to use the scarebird conversion bracket to do rear disc swaps.
MarkCayabyab
Oct 7, 2017 11:40 AM
PaChiLa Leader
Feb 18, 2009 05:21 PM
