The Layout For My Car
Old Feb 6, 2013 | 06:45 AM
RollingFantasyx's Avatar
Post The Layout For My Car
*Before
1.Honda Civic 1999 Ex Coupe Automatic D16Y8
*Now
1.Honda Civic 1999 Ex Coupe Automatic D16Y7
2. W/ Y8 Intake Manifold and all Y8 Components
*Problems
1. Idle stays at (1.5) jumps to (2.5).
2. Check Engine Light
3. Sounds like enigne is sucking in air through a small hose? Hose Split?
*Tryed
1. Throttle Spray + Rag = Smoother Gas Pedal Slide
2. Adjusting Throttle Line
3. Reving the **** Out Of It
Old Feb 6, 2013 | 07:08 AM
JuggerNaut-CTR's Avatar
Default Re: The Layout For My Car
Originally Posted by RollingFantasyx
*Problems
1.Remove IACV and clean it...
2.Pull the cel codes...
3.Check for vacuum leaks, shouldn't be hard to determine where the leak is...
Idle problem is most likely from the vac leak but always a good idea to clean the iacv anyways. Youd be surprised how much carbon will be inside of it.
Old Feb 6, 2013 | 07:09 AM
94EG8's Avatar
Seagull Management
  • What CEL is thrown?
  • What ECU was used? The original Y8 ECU is going to throw codes for Vtec.
  • Did you bleed the cooling system?
Old Feb 6, 2013 | 07:13 AM
Texas4door's Avatar
If you're using a 99 Y8 manifold, there are air injection holes you'll have to block off if you don't have the right equipment to hook up to them:
http://www.d-series.org/forums/diy-f...manifolds.html
That should answer a few of your questions
More technical info on it:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/question-about-99-00-y8-im-manifold-air-injection-1955717/
Old Feb 6, 2013 | 07:20 AM
Cant post attachments yet.
1. Never removed the piece yet. It is green right?
2. Never done this. Maybe a local Pepboys can do this for free?
3. I downloaded pictures of vacuum leaks but haven't really got a good picture to clarify exactly how many vacuum hoses there are, where there are and exactly where they go, plus which need to be blocked off because I know for sure I have 1 screw inside a tube to block something. I do hear pulling air sound somewhere near the top of the intake manifold. Do have Y8 injectors with Y8 Intake manifold on Y7 lol
Old Feb 6, 2013 | 07:25 AM
1. Didnt Get code yet
2. ECU is stock from Honda Civic Coupe EX 1999 Auto D16Y8
3. Not technically. I just kept refilling and cap'd it. Then filled the overflow container. Turned up the heat with a/c. Been 1 week so far.
Old Feb 6, 2013 | 07:27 AM
https://honda-tech.com/forums/showthread.php?t=1955717
Thank You Very Much
Guys, forgot to mention, I've been tweaking with the flat head screw adjustment on the throttle body at this point.
P.s. Will Be Putting on old Y8 Head Cylinder From Previous Y8 "Spun Beaing?" Engine
Last edited by RollingFantasyx; Feb 6, 2013 at 07:31 AM. Reason: Details Details Details
Old Feb 6, 2013 | 07:34 AM
94EG8's Avatar
Seagull Management
  1. Pull the codes. There is a link in the stickys at the top of this forum that describes how to pull CEL codes with a paperclip.
  2. Replace the ECU with a '99 - '00 CX/DX/LX ECU. You also need to replace the transmission with a CX/DX/LX automatic to avoid getting a P0715 code due to a different 3rd gear ratio, as well as harsh shifting.
  3. Park the car on a hill with the front pointed up, run it with the cap off and the heater control turned to hot until the fan comes on. Add coolant as necessary during the process.
Old Feb 6, 2013 | 07:43 AM
1. Will Do
2. If I put my Y8 Head Cylinder on instead do I still have to change Transmission and Electronic Control Unit?
3. Will Do
Old Feb 6, 2013 | 07:57 AM
94EG8's Avatar
Seagull Management
No, but if your Y8 was replaced because it had a spun rod bearing and drove a rod through the side of the block make sure you get the head checked out. Often the piston will come up when the connecting rod breaks and slam into the head bending valves and making some dents in the head itself.
TurboGoKart
Sep 30, 2009 02:53 PM
91daINTEGRAda91
Jun 17, 2009 04:10 AM
unraveled
Apr 16, 2009 09:02 AM
