oil drain plug replacement
Old Feb 5, 2013 | 11:29 PM
98bwahhek's Avatar
Default oil drain plug replacement
hi im going to replace my stripped oil drain plug and was looking into a magnetic plug are they worth getting or should I stick with oem? Do magnetic oil drain plugs really work? N do they help to where its worth getting.
Old Feb 6, 2013 | 12:37 AM
Cap'N Chronic's Avatar
Default Re: oil drain plug replacement
Yes, they attract chunks of metal from your oil so it doesn't get into your bearings and vital parts of your engine. I have one, and every time I change my oil there is a moderate amount of metal on it.
Old Feb 6, 2013 | 09:51 PM
Kohen's Avatar
Your drain plug stripped? Are you sure it's the plug and not the actual pan?
What engine? If it's an aluminum pan, the pan will strip before the plug.
A magnetic drain plug wouldn't be the worst idea. If anything you could just stick some fat magnets on the bottom of your oil pan to attract ferrous metals. It's also a good idea to do the same on transmissions. It's often done and it's proven to be a good thing to do.
Either way, it isn't too big of a deal what you do with the plug.
Old Feb 6, 2013 | 10:00 PM
furious94ls's Avatar
If the pan is ruined, you need an oversized plug that re-threads the pan. You can only use that bolt. They aren't magnetic. Find a new pan and then you can run a magnetic plug. I run a magentic plug in all my cars.
Old Feb 6, 2013 | 10:07 PM
Kohen's Avatar
I've tried those oversized plugs and they freaking blow. I couldn't get it to start threading worth ****.
I bought a used OEM pan to put on and then I was going to retap my old one and sell that with an oversized plug. But my car got totaled before I could get to that point.
In the mean time I was using one of those rubber oil plug things. You put it in and tighten it down and it expands the rubber part. Surprisingly it didn't drop a leak. It's only a few bucks at an auto parts store.
Old Feb 6, 2013 | 10:08 PM
I also just got a used pan in good shape. Good to know about the rubber plugs in case it happens again.
Old Feb 6, 2013 | 10:11 PM
Kohen's Avatar
For my Y8 it was only like $30. Then of course I bought a new oil pan gasket to go with it.
Definitely! I was quite surprised that it didn't drip. I ran it quite a while since it was holding up. I was just going to wait until my next oil change to do the oil pan replacement. But I wasn't able to get enough mileage on it by the time it got totaled to change the oil. Hahaha.
Old Feb 6, 2013 | 10:12 PM
Jimster480's Avatar
If your pan is stripped it might be easier to get a new pan than to try to retap it. Like someone else said, those oversize plugs suck. And yes magnetic is better, I always use them.
Old Feb 6, 2013 | 10:17 PM
Kohen's Avatar
Yupp. And you wouldn't really want to retap it while it is still on the vehicle due to not being able to get a good, straight angle and also because more metal will get into the oil pan.
Old Feb 7, 2013 | 12:55 AM
98bwahhek's Avatar
no its an own oil pan its the actual bolt I have to use vice grips to get it off thanks for the input
Posted from Honda-tech.com App for Android
Old Feb 7, 2013 | 12:57 AM
98bwahhek's Avatar
also does it matter what brand it is? do all magnetic oil drain plugs work the same?
Old Feb 7, 2013 | 01:30 AM
HondaPartsHero's Avatar
Technical Hero
Old Feb 7, 2013 | 09:04 AM
Kohen's Avatar
Gotta love Eric the car guy! Smart man. Great videos. Especially on Hondas.
hydengr
Honda Civic (2001 - 2005)
Jun 11, 2013 03:50 PM
mish__
Nov 16, 2010 07:52 PM
mitch3814
Apr 5, 2005 06:37 PM
AB16A2T
14
Apr 4, 2002 11:32 PM
HankYee
Jul 23, 2001 09:11 AM
