typeR head gasket thickness for boost
im in the process of rebuilding a Type R to boost it and i had a question regarding the head gasket recommendations,,,i was thinkin of running a cometic .030 head gasket but idk if its too thick or possibly too thin.
the build consist of:
stock bore full itr bottom end
type r cp forged pistons
golden eagle rods
block gaurd
ctr head
blox intake
obx tb
xs power 50 trim
log manifold
2 1/2 downpipe
open dumptube
tial waste gate
2 1/2 intecooler piping
goal is to making over 300 whp
golden eagle rods
block gaurd
ctr head
blox intake
obx tb
xs power 50 trim
log manifold
2 1/2 downpipe
open dumptube
tial waste gate
golden eagle rods
block gaurd
ctr head
blox intake
obx tb
xs power 50 trim
log manifold
2 1/2 downpipe
open dumptube
tial waste gate
golden eagle rods
block gaurd
ctr head
blox intake
obx tb
xs power 50 trim
log manifold
2 1/2 downpipe
open dumptube
tial waste gate
i had the cometic headgasket setup on stock internals that lowered compression down to 9.5:1 and made 307 whp @ 7 psi..
I had a garret but ended having major shaft play instead of rebuilding it I was offered this as a trade for some stuff I had laying around but ill end up buying another just need to get it up and running again....I miss driving that lol ******
i wouldnt go past 10:1 on the compression theres been alot of testing and i took apart my motor to change my pistons keep it at 10 or higher mine has 10.5:1 in it now it helps with torque
I have luckily never had any issues with Cometic. I'm running a .040" cometic due to the block having been decked and the head also resurfaced. If it wasn't for that, I'd probably be running an OEM gasket (.030")
that still has nothing to do with the actual turbo, just the size of the exhaust case. you can stick 50, 57, 60 trim and a host of others in that same size of casing. all have completely different boost maps
because they have to know exactly what you want out of the car to know what exactly recommend..
ive already answered your question and you feel it wasnt good enough of an answer.
strigga
Sep 28, 2018 05:58 PM
dartonh22
Apr 27, 2008 07:31 AM
