Turbo Coolant Line Routing
Old Feb 5, 2013 | 06:27 PM
InTheZoneAC's Avatar
Default Turbo Coolant Line Routing
I know it's been asked over and over and there are many different ways, I just want to be clear on a way I haven't seen yet, as simple as it sounds to me....
With my new turbo set up can I just weld two an fittings to my mishimoto radiator, one at the top and one at the bottom? Then just run both lines directly to turbo...I mean this sounds very simple and it seems it would have the best cooling efficiency just because it's pulling coolant from the coldest spot in the cooling system.
I would use the block plug on the back of my Y8 but I will be installing a sandwich adapter with sender units and lines going to an oil cooler and the only way it clears everything back there is if I have it turned in a way that the lines block the coolant plug.
Old Feb 5, 2013 | 06:45 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: Turbo Coolant Line Routing
i do not think there will be a pressure differential if you plumb them both to a radiator.
you need a source of vacuum on the return. i have it plumbed from the intake manifold coolant outlet and back into the thermostat housing, after the thermostat, where the pump creates negative pressure, pulling the coolant through the turbocharger.
Old Feb 5, 2013 | 08:00 PM
slowtegkauai's Avatar
There isn't anything in the turbocharger that circulates your ethylene glycol or coolant like a water pump does. If that's what you were thinking.
On my set up I would plumb the lines as Ash said. That would allow coolant to be drawn thru your turbine case at all times the engine is running.
Now, when you turn off your engine, thermal convection takes place. The high heat absorbed from the turbocharger causes the water to move up while drawing in cooler water from its lower water source. This is why most people plumb their lines to take advantage of this benefit.
Old Feb 6, 2013 | 07:23 PM
TurboSource's Avatar
I agree, take proper precaution when choosing your coolant line design. Here is an 'oldie but a goodie' when it comes to turbo optimization...
http://turbobygarrett.com/turbobygar...il_water_lines
Old Feb 6, 2013 | 08:55 PM
TheShodan's Avatar
Moderator
In the FAQs!!
http://turbobygarrett.com/turbobygar...er_Cooling.pdf
Old Feb 12, 2013 | 06:29 PM
xile6's Avatar
I tap off the fast idle valve lines. I know they pump out pressure.
b20forlife
May 14, 2009 05:11 AM
powerdbygarrett
Mar 13, 2009 10:53 AM
Mr.Death
Jul 17, 2008 04:38 PM
hondapimpin420
May 17, 2007 09:41 AM
Rubixcu7
Jul 11, 2005 08:27 PM
