92-95 civic knuckle/spindle assembly interchangeable?
Old Feb 4, 2013 | 04:47 PM
ervstr's Avatar
Default 92-95 civic knuckle/spindle assembly interchangeable?
i got a 94 hatchback CX no power steering and the hub/bearings are bad so i bought a whole used complete knuckle from a 93 civic 4 door DX with power steering.
everything bolted up but the tie rod hole it seems like the hole is bigger from the 4 door knuckle/spindle.
my questions are:
-do i need to use the 4 door outer tie rod end?
or
-could i press out the hub on both knuckle assembly and swap them would it fit?
any info would be appreciated thanks!
Old Feb 4, 2013 | 06:16 PM
rice a roni's Avatar
look up the parts number and see if they se similar
Posted from Honda-tech.com App for Android
Old Feb 4, 2013 | 06:44 PM
94EG8's Avatar
Seagull Management
Default Re: 92-95 civic knuckle/spindle assembly interchangeable?
The knuckles are identical. If the hole is larger it's worn (loose tie rod end stud moving around in side the hole might have enlarged it)
Old Feb 4, 2013 | 09:41 PM
ervstr's Avatar
Yeah ill press out the hub n bearing on both knuckles tommorow hopefully the hub and bearings is interchangeable as well
Old Feb 5, 2013 | 03:44 AM
94EG8's Avatar
Seagull Management
All of it is the same, part number for part number.
dele22
13
Oct 12, 2011 09:11 AM
96 GSR-T
Nov 22, 2008 05:58 PM
quicksilver1689
Jan 9, 2006 05:33 PM
2000Accord5sp
Nov 20, 2002 08:00 AM
mantic6t9
Sep 30, 2002 09:19 PM
