b16 cam seal replace, timing belt tension question
Old Feb 3, 2013 | 07:57 AM
markward90's Avatar
Default b16 cam seal replace, timing belt tension question
hey honda tech im not new to b series or timing . Just wondering if its possible to tighten belt properly without removing lower cover.. yes i have full timing cover on my b16. I have the lower mark and cam gears aligned it just trying to add tension with removing lower cover, only reason is because I'm in an apartment complex and I know they will not approve of me using a jack to raise car to pull crank pulley/plastic cover off to apply tension that way to timing belt? I'm mechanically inclined and have had b series engines for awhile.
Old Feb 3, 2013 | 08:00 AM
markward90's Avatar
Default Re: b16 cam seal replace, timing belt tension question
I was think of slightly rotating crank a hair then tighten tensioner bolt. Just want some other opinions?
Old Feb 5, 2013 | 05:03 PM
markward90's Avatar
I was able to apply appropriate tension without removing lower cover while in vehicle with no jack ... Thanks anyways Honda-tech...
Old Feb 5, 2013 | 05:05 PM
markward90's Avatar
Any questions feel free to ask if unsure how I was able to remove cams to replace cam seals and set timing.
Old Feb 6, 2013 | 10:40 PM
turbohatch96y7's Avatar
youre a crazy bastard fordoing that. Is the timing still spot on?
Old Feb 7, 2013 | 08:34 AM
accorse07's Avatar
So you removed upper/outer cover and used a wire hanger to pull the tensioner tight whilst tightening the 14mm bolt that can be accessed by removing s small rubber plug on the lower cover...should have known how to do this in the first place since your not new to B-Series or Timing.
JwithTHEek
Jan 21, 2009 09:38 AM
honDA16
Dec 6, 2004 06:03 PM
NX_LS
Oct 14, 2003 02:49 PM
Honda Kustums
Aug 19, 2003 06:36 PM
2camsaam
Aug 1, 2003 06:40 AM
