Front/rear brake conversion
Old Feb 1, 2013 | 07:57 PM
B16KENNY's Avatar
Default Front/rear brake conversion
I got a 96 ek coupe dx wit a b16 I'm gonna do a rear brake conversion with 94-01 integra parts and I kno I need an 99si prop valve but my question is
Can I use the front assembly (knuckle, caliper, etc) from the same integra?
Old Feb 1, 2013 | 08:19 PM
Marvin1985's Avatar
Default Re: Front/rear brake conversion
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-put-x-brakes-your-96-00-ek-civic-revised-upgrade-chart-1513752/
Old Feb 1, 2013 | 08:32 PM
jdm_phunk's Avatar
http://www.knology.net/jediklc/brakeinfo.htm
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faqs-frequently-asked-tech-questions-1998336/ -section 13
Old Feb 1, 2013 | 09:00 PM
98civdx's Avatar
Master Detailer
No, leave the prop valve alone.
You can, however the knuckles are different. I would recommend trying to find a 96-00 EX, or 99-00 knuckles. For the rear it doesn't matter. 92-00 it all fits.
Old Feb 1, 2013 | 09:20 PM
B16KENNY's Avatar
So this is what I'll need to do the brake conversion for front and rear... Everything from an ex/si right?
Brake Booster – Master Cylinder – Prop. Valve – Brake Lines – Caliper – Brake Pad – Rotor.
Old Feb 1, 2013 | 09:35 PM
BiggieBert's Avatar
Loved
Community Favorite
search man.... its a sticky...
https://honda-tech.com/forums/suspension-brakes-54/brakeexperts-brake-chart-thread-civic-brake-upgrades-ef-eg-ek-integras-3044628/
Old Feb 1, 2013 | 09:51 PM
98civdx's Avatar
Master Detailer
Leave the booster alone.
The MC will depend on what FRONT calipers you end up using.
Old Feb 1, 2013 | 10:22 PM
B16KENNY's Avatar
Well I was gonna get rear integra trailing arms the whole assembly and I was gonna get the integra front knuckle assembly... So out of the prop valve brake booster and MC... Should I grab all 3 or what?
Cuz I know integras have bigger pistons in the calipers right...
Old Feb 1, 2013 | 11:49 PM
BiggieBert's Avatar
Loved
Community Favorite
find out if your prop valve is part number 46210-S04-902 if so it is already the one you need.. it should be.
Old Feb 2, 2013 | 04:58 AM
B16KENNY's Avatar
Ok ya that's the one I have... So can I leave them 3 parts alone?(prop valve, booster, and mc)
Old Feb 2, 2013 | 07:10 AM
BiggieBert's Avatar
Loved
Community Favorite
Look at your mc, there will be a fraction on it. If it says 7/8 or 15/16 you do not need to upgrade mc/booster.
Old Feb 2, 2013 | 07:28 AM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Why don't you read the links provided!!! You can't use integra knuckles on a ek due to being longer than ek's.
Old Feb 2, 2013 | 07:30 AM
B16KENNY's Avatar
Ok cool... Thanks alot for the help man... It's jus I got the car with the b16 in it and both my front calipers are frozen and my brake pedal goes down to the floor and I have no idea what set up it has... So I was gonna convert the rear to disks and take the front assembly also so I don't keep buying wrong parts
Old Feb 2, 2013 | 07:32 AM
B16KENNY's Avatar
I did read them I'm not using integra knuckles... I kno I gotta use ex knuckles
Old Feb 2, 2013 | 07:40 AM
98civdx's Avatar
Master Detailer
That's why I said the MC will depend on the front calipers.
Yes, the DC front calipers have larger pistons, so you would the MC to match those calipers.
96-00 EX/SI= get a 96-00 EX/SI MC.
Old Feb 2, 2013 | 07:49 AM
B16KENNY's Avatar
Ok one more question...
If I got integra rear conversion would i be ok wit ex/si fronts?
Or should I jus get all 4 from the integra? (Except the ex front knuckle of course)
Old Feb 2, 2013 | 08:07 AM
98civdx's Avatar
Master Detailer
it doesn't matter.
Old Feb 2, 2013 | 08:17 AM
B16KENNY's Avatar
Ok cool thanks for the info
leiper1
Aug 22, 2015 02:11 PM
CrAzE191st
Aug 30, 2010 05:31 AM
jhec23
Mar 29, 2006 02:48 PM
TGrant
Dec 5, 2004 08:06 AM
Excelerate
Mar 22, 2004 01:42 PM
