Loud Blower Motor
Old Feb 1, 2013 | 01:36 AM
deerman2701's Avatar
Default Loud Blower Motor
Hey all, I have a 99 civic LX and everytime I have the heat or ac on there are there is a loud noise coming from under the passenger where the floor board.
Can I lubricate a part in it or should I just replace the whole blower motor? It makes a growling noise.
Old Feb 1, 2013 | 06:42 AM
axis11's Avatar
Default Re: Loud Blower Motor
Take out the blower motor and inspect (3 screws under the blower housing). Often times leaves and other debris get caught on the impeller. The blower motor itself is a PITA to disassemble. it is more likely that you will break something inside before you get to the bearings.
Old Feb 1, 2013 | 08:04 AM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Can you describe the noise? Above ^^^ user is correct that leaves and crap get in there, but I've also had a case where a NEWER blower motor had noisy brushes on the motor and caused an annoying ticka-ticka-ticka noise. Aggravating.
Old Feb 1, 2013 | 10:37 AM
killrroyale's Avatar
have the same issue with mine. took it apart found leaves and the like in there. cleaned it all up and still makes the same noise just going to call it loose brushes and worn out bearings. headed to the pick apart for a good used one.
Old Feb 2, 2013 | 06:46 AM
markward90's Avatar
Sounds like leaves or something similar... Description of sound will help diagnose your problem
Old Feb 2, 2013 | 08:30 AM
dazebreak's Avatar
http://www.tomsmm.com/carnoises.html
Or maybe record it and link to a sound file?
Old Feb 2, 2013 | 12:50 PM
It sounds pretty much like this
Old Feb 2, 2013 | 06:33 PM
dazebreak's Avatar
Originally Posted by deerman2701
It sounds pretty much like this http://www.youtube.com/watch?v=7YimG8ROz1E
This is your car, or pretty much sounds like this? I have not dealt with this before, but imo it sounds like a bearing and not leaves. But why not remove it and find out if it is debris or not? If not, get one at j-yard.
Old Feb 2, 2013 | 11:17 PM
EL Vap133's Avatar
Yup, leaves got into mine and made a ton of noise. Took it out and cleaned it from debris and it was much better.
Old Feb 3, 2013 | 05:41 AM
axis11's Avatar
Remove the motor and see what is wrong.Just 3 screws on the outer circle and a connector and your done in 10 minutes or less. Disregard the 2 screws on the motor itself.
Old Feb 3, 2013 | 05:47 AM
cvcrcr99's Avatar
Bearing noise from my experience. Both mine and my bro's 98 Civic did this. Reaplced them with known working units.
Old Feb 7, 2013 | 11:30 AM
Well I took out the blower motor out and turned it on and the fan was quiet... it only makes the noise when the blower motor is installed in the car????
Any suggestions?
Old Feb 7, 2013 | 11:32 AM
deschlong's Avatar
Loved
Community Favorite
Start looking for crud on the inside. Get out the Shop Vac and go to town.
Old Mar 18, 2022 | 08:52 AM
ZachA's Avatar
Any suggestions?
What did you end up doing to fix this? currently have the same problem where it spins freely and then once screwed into place grinds on something inside.
No debris
Old Dec 8, 2022 | 04:46 AM
VELEZRA's Avatar
No debris
Have you been able to figure out what the problem was because i have to same thing
Former User
Nov 28, 2012 11:10 AM
jredhonn
Aug 31, 2008 01:05 PM
empirejr
Honda Civic (2001 - 2005)
Aug 7, 2007 09:38 AM
MrD
Honda Civic (2006 - 2015)
Dec 10, 2006 12:56 AM
rizen
Sep 30, 2003 04:10 AM
