98 civic dx hatch just lost acceleration while driving! help plz
Old Jan 31, 2013 | 11:01 AM
sppaille's Avatar
Icon2 98 civic dx hatch just lost acceleration while driving! help plz
Was driving and car just had no accelleration. Had it towed home. Check for spark with none firing. Then went into distributor to do a coil icm test and got as far as rotor. Cannot access the screw to remove rotor. Turned driver wheel far left and manually cranked the engine with 17mm a couple turns and rotor has not moved its postion. I am thinking its timing. But im not sure if i should have the wheel off or car jacked for the manual cranking to work. I have car in nuteral also. Any suggestions? Any help will greatly be appreciated. I am partially disabled and have no income so I will try my hardest to do as much as i can. Thanks and God Bless
Old Jan 31, 2013 | 11:13 AM
Former User's Avatar
Default Re: 98 civic dx hatch just lost acceleration while driving! help plz
Snapped timing belt or camshaft.
Remove the valve cover and upper timing belt cover to check.
After you fix the problem, compression test the cylinders to check for possible engine damage.
Old Jan 31, 2013 | 11:17 AM
sppaille's Avatar
Darn it. Was hoping for anything but that and trying to avoid the truth in the back of my head. Do you think id be able to to a change myself? If so do i have to replace the wp and alt and the other things with it or just belt ok? What you suggest. BTW THANKS SO VERY MUCH. Ive been searching everywhere for 2 hrs trying to figure this out. Live 1 hr away from town too. Humph. ;(
Old Jan 31, 2013 | 11:22 AM
Wait on the other things.
Start by checking whether the timing belt snapped.
If it did, then install a new one. This job requires removal of the crank pulley bolt, which can be difficult if you are new to cars.
Then compression test the cylinders. Engine damage occurs about half the time when the belt snaps or strips. Good luck.
SeaMus MaCk
10
Mar 31, 2014 06:59 AM
hatchyboy89
10
Jul 17, 2012 02:19 PM
jason0123
Aug 4, 2009 05:37 PM
Dark Star
May 7, 2008 11:23 AM
steve495
Dec 14, 2004 05:22 PM
