Eg coupe bogging
Old Jan 30, 2013 | 07:40 PM
fumes510's Avatar
Default Eg coupe bogging
So i have a 1994 eg coupe with a stock z6 and 220xxx miles, and i didnt drive it for about 3 months because i need new tires and i needed to replace the distributor o ring. Well i replaced the o ring and got new tires and i started it up and it hesitated to start up, like it was bogging and the motor was just shaking. It took like 3 cranks to turn it on. So I decided to let it warm up and drive it around the block, and when i was doing i was in 3rd gear going about 30 mph when there was like a loss of power. And I pulled up to a stop sign and it didnt want to go any more, i had it in first and it would barely move and then it turned off. I turned it back on and it drove fine. What do you think it can be? Tune up maybe.
Old Jan 30, 2013 | 08:30 PM
ktegra17847's Avatar
Default Re: Eg coupe bogging
well did you mark the distributor when you took it apart? sounds like your gonna need to reset the ignition timing with a timing light.
Old Jan 30, 2013 | 09:04 PM
fumes510's Avatar
Yes I did mark it, and it lined up exactly where it was marked. How do I reset the ignition timing?
Old Jan 30, 2013 | 09:08 PM
Former User's Avatar
Do the tune up you mentioned, replace the fuel filter, and then check the ignition with a timing gun (see FAQs sticky for diagram).
EG92DX
14
Jun 21, 2013 07:07 AM
BmoreEG
Apr 6, 2013 02:41 PM
JDM_CAM
Mar 24, 2012 04:52 PM
HungLoSavage
Transmission & Drivetrain
Sep 3, 2010 07:03 AM
