interior light wont turn on with doors open
Old Jan 30, 2013 | 06:10 PM
redtegy's Avatar
Default interior light wont turn on with doors open
interior light wont turn on with doors open. it will turn on with the switched on though. whats the deal?
Old Jan 30, 2013 | 06:27 PM
Texas4door's Avatar
Default Re: interior light wont turn on with doors open
Do you have your factory radio still?
If not, that's your problem, as the circuit for the light is run through the factory radio (as is the keyless entry)
You'll have to install something aftermarket to make use of it (or get a tap light)
Old Jan 30, 2013 | 06:43 PM
Former User's Avatar
What car?
Old Jan 30, 2013 | 07:14 PM
gplock's Avatar
open the door n move the switch to off n slowly to on.. see if that works. mine was doing the same n had to do what I said n it works fine now. she's just picky
Posted from Honda-tech.com App for Android
Old Jan 30, 2013 | 07:57 PM
redtegy's Avatar
it does have a sony deck in it. tried the switch idea but didnt work. also car is a 98 civic hx coupe 5spd
Old Jan 30, 2013 | 08:03 PM
This^...if you have power locks.
The fix is to jump two wire terminals in the unplugged keyless connector behind the radio. A search will tell you which specific wire terminals to jump.
Old Feb 1, 2013 | 05:20 PM
redtegy's Avatar
ok so i took my sony deck out and plugged in the "2" plugs including the green one and the interior light came on. so i know its the green plug but which 2 terminals do i jump? thx again for the help guys.
Old Feb 1, 2013 | 05:22 PM
grumblemarc's Avatar
The Grumpiest
You didn't have to take the deck out.
https://www.google.com/webhp?sourcei...w=1899&bih=844
Old Feb 1, 2013 | 05:41 PM
redtegy's Avatar
hey thanks for that. im gonna jump those in a bit.
Old Feb 1, 2013 | 05:51 PM
The Grumpiest
Don't cut them or expose any wire. Just use a paperclip to jumper the connector.
Old Feb 1, 2013 | 06:05 PM
redtegy's Avatar
i was just gonna use these little wire tap things i got that way nothing can fall out.
Old Feb 1, 2013 | 06:13 PM
The Grumpiest
I used a paperclip. bent it. Inserted it into the plug at the proper pinouts. And just used a strip of electrical tape to cover it.
EKing
Audio / Security / Video
Dec 24, 2009 05:42 AM
traxxasx
Mar 12, 2008 07:17 PM
CivicBlack
Apr 24, 2006 11:08 PM
wishingiam
Mar 17, 2005 09:06 PM
QuickHX
Oct 11, 2004 03:28 AM
