inconsistant power issue
Old Jan 30, 2013 | 06:10 PM
dns92civhatchcx's Avatar
Icon3 inconsistant power issue
so i got an issue with my car with power. so basically what happens is some days my car has pretty good power, more than you would expect from my car and then some days i have very little power or acceleration or the feeling of "pulling" but on the days i do have good power it "pulls" pretty strong and accelerates pretty good imo. i have a 92 civc hatchback cx with oem clutch trans flywheel ect. original motor which is a d15b8 with 330xxx. also based on 1st-4th gear pulls at 3500rpm in a 5speed obviously. so im just wondering what could be the problem? is something about to go out? or is this a sign of anything??
Old Jan 30, 2013 | 06:24 PM
Former User's Avatar
Default Re: inconsistant power issue
330K miles? Have you compression tested the cylinders?
Last tune up?
CEL codes?
Clogged cat?
Old Jan 31, 2013 | 03:33 PM
Last tune up?
CEL codes?
Clogged cat?
yes 330k, no compression test i don't really know how to. tune up probably 3 or 4 years ago, i haven't had any cel codes come up or check engine light come on in a long time, and i don't have a cat or resonator just straight pipe with fart can and ebay header.
Old Jan 31, 2013 | 03:48 PM
SloHa+ch's Avatar
check compression and do a tune up.report back
Old Feb 2, 2013 | 12:04 PM
will do.
Dxciv97
10
Jun 5, 2013 06:43 AM
RJason1111
Apr 5, 2009 03:14 PM
RSX_S
10
May 20, 2008 11:25 AM
precord96
Feb 2, 2005 02:34 PM
