Best route for 250-300 hp on a civic or del sol?
Old Jan 30, 2013 | 08:58 AM
AMar55's Avatar
Icon2 Best route for 250-300 hp on a civic or del sol?
Like the title states I am currently looking for a nice buy on a civic or del sol to fix up with the ultimate goal of getting it anywhere between 250-300hp. So my questions are which would be better to use a civic coupe 4dr or hatch or a del sol and whats going to be the best route to take in getting the desired hp estimate cost after getting the car? Thanks for the help.
Old Jan 30, 2013 | 09:02 AM
98civdx's Avatar
Master Detailer
Default Re: Best route for 250-300 hp on a civic or del sol?
Pick the car you like the most and do it. Don't worry about what anyone else says.
Google vitara/eagle.
Old Jan 30, 2013 | 09:07 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
whatever body you prefer, then turbo d series or turbo b series.
Old Jan 30, 2013 | 09:08 AM
B20DelSol's Avatar
pick your chassis, and go full bottom end build up, turbo, and a really good tune....
actually...one thing you may want to try to get is a pre-96 Honda. OBD-I (or OBD-0) is chippable and tunable.
Or if you go with an engine swap and want OBD-II, a K-series swap with its respective OBD-II ECU will work as well because you can tune the K-series ECU (Using the Hondata Products)
Like 98civdx said....pick what you like the most and build it how you want it.
Old Jan 30, 2013 | 09:21 AM
AMar55's Avatar
What about a b16 swap how much do you think that would run with a tranny as well?
Old Jan 30, 2013 | 09:30 AM
B20DelSol's Avatar
$2000-3000 is what I would budget
Old Jan 30, 2013 | 09:33 AM
AMar55's Avatar
Okay would 250-300 hp be realistic with a b16 with no problem, and is that with all things i would need for the swap or just the motor and tranny
Old Jan 30, 2013 | 09:46 AM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
It all depends on where you buy your swap. I wouldn't touch a b16 when you can get a b18.
You need to spend a little reading other people's builds with similar goals and copy their build.
Old Jan 30, 2013 | 09:58 AM
AMar55's Avatar
Okay thanks alot.
Old Jan 31, 2013 | 09:12 AM
AMar55's Avatar
What about a b20? or just stick to a 16/18?
Old Jan 31, 2013 | 09:15 AM
doctorake's Avatar
Community Builder
What is your budget?
Old Jan 31, 2013 | 09:17 AM
AMar55's Avatar
To spend off the bat about 5000-5.5
Old Jan 31, 2013 | 09:27 AM
Fnix's Avatar
cheapest horsepower/dollar ratio = turbocharge. The car you use is based on your personal preference.
Old Jan 31, 2013 | 09:42 AM
AMar55's Avatar
Well i am set on trying to find a 95-00 hatchback but right now where i live there is nothing less than 2 hours away so it will for sure be a hatch or sol when i can find one. Then just finding the best swap and mods from there.
VTECwalka's Avatar
It's really what you like the best. Hatches have less weight to them so that's always a favorite, Coupe(what i have) in my opinion looks good all around. I think hatches look weird. A sedan then would have the most weight too it because of the doors.
I would go with a rebuilt B18 then turbocharge it and tune the ECU with a hondata. (a tune is a MUST)
But make sure you like what you are getting and do research before buying.
Old Jan 31, 2013 | 09:57 AM
dirty19's Avatar
Ridin Dirty in Cali
how about a J32?
Old Jan 31, 2013 | 10:02 AM
B20DelSol's Avatar
Originally Posted by dirty19
how about a J32?
Now this has gotten interesting!
I want someone to post up a current J-series swap just to see how that monster gets put in.
Old Jan 31, 2013 | 10:53 AM
grumblemarc's Avatar
The Grumpiest
How about we use the SEARCH function or use Google? It's not like it's anything new.
Old Jan 31, 2013 | 11:18 AM
jdm_phunk's Avatar
Start Here(thanks to Grumblemarc)---> https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/guide-answer-common-question-just-bought-civic-how-do-i-make-faster-2915974/
http://www.j32a.com/
http://www.hmotorsonline.com/shop/sc...ry&keyword=JDM USDM Engines
http://www.go-autoworks-store.com/
read search read search read!!
Old Jan 31, 2013 | 12:05 PM
Not true in a lot of cases. A 99-00 civic sedan is lighter than a coupe and a hatch
Old Jan 31, 2013 | 01:11 PM
Schister66's Avatar
Man U FTW
A mildly built D series (Eagle/Vitara) or a stock B series will make that kind of power. The best overall mix of cost vs power is an LS or LS/VTEC swap IMO. The best suggestion any of us can give you is this: Do your homework and pick the setup that fits your goals and budget the best. Everyone has preferences as to what they would do, but until you sit down and figure out the Pros and Cons, you're reliant on other people to make your decision for you. Check out the Forced Induction FAQ...it will shed some light on your options
Old Jan 31, 2013 | 01:46 PM
DumpdEJ6's Avatar
I like the tuna here
How is a stock B-series going to make 250+hp?
Old Jan 31, 2013 | 01:50 PM
The Grumpiest
With a turbo on it.
Old Jan 31, 2013 | 02:15 PM
DumpdEJ6's Avatar
Doh! :slapsface:
William Reklaw
Dec 4, 2017 12:17 PM
joshua deville
Jun 12, 2017 07:52 AM
dafiltafish
May 7, 2015 05:06 PM
andrew19owens
24
Feb 20, 2012 06:55 AM
trenenbaum
Jul 22, 2006 07:48 PM
