10 point cage floor bar ??
Old Jan 29, 2013 | 09:28 PM
hondab18b67's Avatar
Default 10 point cage floor bar ??
Haven't welded up a 10 point cage in a quite a while,anyone got some pics of the new floor bar under the roll bar I have an idea of how it goes,but is there a certain way it goes to meet the rules..
Old Jan 31, 2013 | 02:15 AM
siblues's Avatar
Default Re: 10 point cage floor bar ??
Dont quote me on it but from my understanding it is not supposed to be welded to the main hoop and should not be bent.It should be either welded in front or behind the main hoop.
Old Feb 4, 2013 | 03:19 PM
ekcoupeh22's Avatar
Here ya go I just finished mine the lower bar has to tie into the rockers not the hoop and your short down tubes tie into the rocker bar
Old Feb 4, 2013 | 03:34 PM
theidealone's Avatar
Thats EXACTLY how I did mine. Doesnt say it cant be bent in the rules. But does say cant tie into main hoop.
I honestly dont see a way you could go about not bending it, unless you cut a hole in the tunnel. But then Im sure you wouldnt fit some classes, as the floor cant be modified, kinda thing.
Old Feb 4, 2013 | 04:53 PM
tepid1's Avatar
It can tie to main hoop, but then the d-bars need to go to tunnel walls with plates, not the cross bar like above.
Old Feb 4, 2013 | 06:44 PM
siblues's Avatar
I was told it wasn't supposed to tie into the hoop and that the d bars go onto the floor bar. He also said it wasn't necessary but it was a better option not to bend the floor bar assuming you could install it that way. This is from the nhra directly but he also said it depends on who is creating the car
Old Feb 4, 2013 | 10:08 PM
redboost10's Avatar
best thing to do is ask your local nhra cage cert guy. everyone has a different opinion on it. i had mine going from main hoop to main hoop and it was totally fine.
Old Feb 5, 2013 | 07:53 AM
Thanks for the pic keep up the good work,and thanks guys on the feedback,anyone have a link to the new rule book?
Old Feb 5, 2013 | 08:08 PM
redboost10's Avatar
what information are you looking for?
Old Feb 6, 2013 | 04:18 AM
EJ1_Ex's Avatar
does that floor bar go behind the main hoop or in front? the teg it's welded behind, i've seen some welded infront.
Old Feb 6, 2013 | 07:27 AM
h2.4's Avatar
[QUOTE=ekcoupeh22;48420485]Here ya go I just finished mine the lower bar has to tie into the rockers not the hoop and your short down tubes tie into the rocker bar
Off topic, but is your windshield going to clear? Maybe it's just the camera angle. And to above post, the main hoop is behind the floor bar, which You probably don't want to put the floor bar behind, pushing the main hoop foward.
Old Feb 6, 2013 | 07:44 AM
ekcoupeh22's Avatar
it doesn't matter
[QUOTE=h2.4;48426857]
It's just the camera angle. It's about 1.5 inches below the seam for the windshield
Old Feb 7, 2013 | 03:53 AM
EJ1_Ex's Avatar
can someone tell me how long the floor bar is when bending it like the teg?
chinkyx90
Suspension & Brakes
Mar 11, 2009 03:43 AM
Live*JDM
Suspension & Brakes
Dec 20, 2007 07:25 AM
LSVTECoupe
Jul 23, 2003 12:20 AM
morepoop4u
Oct 17, 2002 02:09 PM
