d16z6 misses when accelerating or shifting gear
Old Jan 28, 2013 | 02:58 PM
jdmjunky45's Avatar
Default d16z6 misses when accelerating or shifting gear
Okay so i a d16z6 and it misses when i accellerate or shift into the next gear ive changed the wires plugs and distributor cap but not the button. Its also done it once before but it wasnt as bad and i put injector cleaner in it and stopped for a little while i tryed that again this time but no luck. So im thinking either bad injector or rotor button. But i also have a oil leak from what looks like its coming from right under the distribtor and vtec silonoid could this be a blown head gasket and could that cause this ?
Old Jan 28, 2013 | 03:04 PM
dirty19's Avatar
Ridin Dirty in Cali
Default Re: engine help!!!
Doubt its a blown head gasket.
Are you leaking oil from that area?
Did you check your plugs?
Old Jan 28, 2013 | 03:38 PM
jdmjunky45's Avatar
yes its leaking from that area, not a big leak but is leaking. and yes ive changed wires and plugs
90civic1.5
16
Nov 29, 2012 10:11 PM
Elitesky
Jul 28, 2010 06:05 AM
j_dee1st
Apr 24, 2008 07:12 PM
fast+forward
Oct 19, 2003 11:54 AM
