car died
Old Oct 18, 2003 | 12:17 PM
fast+forward's Avatar
Default car died
hopefully you guys can help me out...I was getting on the freeway on 2nd gear at 5500rpms getting ready to shift to 3rd, then my car just dies...no loud clunk or explosion...just a silent death. Got it towed home, checked the oil and coolant levels and both were pretty low. Before it died I made sure to top off the oil and coolant, so i was pretty surprised to see them both low. I'm thinking, it might be the head gasket, but i'm not so certain as to what the symptoms would be, and I was told my car would start even w/ a bad head gasket. So what could the problem be?
oh yeah, motor is a jdm h22, replaced all belts, hoses, pumps, plug wires, plugs and dizzy
ANY HELP IS VERY MUCH APPRECIATED THANKS!
Old Oct 18, 2003 | 02:32 PM
Chiovnidca's Avatar
Default Re: car died (breakaway)
Does it have spark?
Old Oct 18, 2003 | 02:34 PM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
did u replace with a "new" dizzy?..when the igniter or coil u usually go bad the car will just die with no warning or symptoms...check and see if your getting spark doesnt sound like a gasket to me.
Old Oct 18, 2003 | 02:40 PM
Default Re: car died (bruceleeroy)
yup, brand new distributor
Old Oct 18, 2003 | 04:17 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by breakaway &raquo;</TD></TR><TR><TD CLASS="quote">yup, brand new distributor</TD></TR></TABLE>
Does it have spark?
Old Oct 18, 2003 | 06:54 PM
chrisCNL's Avatar
Default Re: car died (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
Does it have spark?</TD></TR></TABLE>
Yeah does it???
Old Oct 18, 2003 | 09:32 PM
Default Re: car died (chrisCNL)
no spark, BUT the plugs look like the metal part/electrode? just disappeared...just the ceramic part of it left...any ideas? BTW, i drove around for the better part of 3 days w/out the o2 sensor and running rich because of it (had finished swap and o2 sensor plugs were wrong), shot flames out of my header everytime i shifted...would this have caused the plug failure?
Modified by breakaway at 7:13 AM 10/19/2003
Modified by breakaway at 7:14 AM 10/19/2003
Modified by breakaway at 7:27 AM 10/19/2003
Old Oct 18, 2003 | 10:14 PM
Old Oct 19, 2003 | 07:00 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by breakaway &raquo;</TD></TR><TR><TD CLASS="quote">no spark, BUT the plugs look like the metal part/electrode? just disappeared...just the ceramic part of it left...any ideas? </TD></TR></TABLE>
Do they look melted? What mods have you done to the engine?
Old Oct 19, 2003 | 09:03 AM
Stock engine, no major mods except intake and exhaust. There's just a small black dot where the metal electrode is s'posed to go, doesn't look melted at all. I replaced the plugs, but still no spark, any ideas...
thanks for the replies
Old Oct 19, 2003 | 09:27 AM
Chiovnidca's Avatar
Broken t-belt? Blown fuse?
Old Oct 19, 2003 | 09:54 AM
chrisCNL's Avatar
take off your distributor. have some crank the and you check the cam if it is rotating. if is not, broken t.b. if it is something is wrong with your distributor assy.
Old Oct 19, 2003 | 11:19 AM
k, just checked underhood fuses, 15A FI E/M fuse is blown...what does this fuse do?
update: on me...it was 15cent fuse that caused me all this grief, thanks for your help guys, mucho appreciado
Modified by breakaway at 8:46 PM 10/19/2003
Old Oct 19, 2003 | 11:50 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by breakaway &raquo;</TD></TR><TR><TD CLASS="quote">k, just checked underhood fuses, 15A FI E/M fuse is blown...what does this fuse do?
LOL, they don't run very well when the ECU dosen't have power. Hopefully it was just a one time thing.
Old Oct 19, 2003 | 11:54 AM
yea, hopefully its this sudden heatwave down here that's caused it to blow
marinj87
May 7, 2019 11:47 AM
ToKicO
May 9, 2011 03:21 PM
99accord_van
Sep 2, 2008 06:36 PM
boosted96midorihatch
Oct 9, 2006 03:03 AM
machine4321
Jul 2, 2004 11:56 AM
