Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2003 Civic Ex Running light problem
Old Jan 28, 2013 | 12:47 PM
Themouse's Avatar
Default 2003 Civic Ex Running light problem
Having an issue with the rear running lights. they aren't turning on with the headlights, nor is the instrumental panel lighting up on the interior.
We replaced all the bulbs, checked all the fuses, replaced the switch for the lights on the left side.
Don't know what else it could be if anyone has any insight that would be much appreciated thanx!
Old Jan 28, 2013 | 04:38 PM
lazlong's Avatar
Default Re: 2003 Civic Ex Running light problem
Turn the running lights on then check for voltage at the light. If you have voltage at the light then it's either a bad light socket (which I doubt as none of them are working) or it's a bad ground. The ground for all those lights is under the trunk latch on the rear wall of the car.
If you don't have voltage at the light, check for voltage at the taillight relay socket in the under-dash fusebox. If you have voltage at the relay socket then check to see if the relay is good.
Beeken
12
Nov 11, 2016 03:41 AM
spark66
Jan 21, 2008 02:43 PM
CivicHB93JDM
Dec 19, 2006 06:49 PM
Metal Typhoon
Oct 17, 2006 05:14 PM
