Help! Problem with lighting
Old Dec 19, 2006 | 06:14 PM
CivicHB93JDM's Avatar
Default Help! Problem with lighting
Greetings,
I have a 95 Honda Accord EX-V6 that is experiencing lighting problem. Here is the problem and what I have done to test.
1.When you turn on the first light switch that controls the tail lamps, cluster light, heat and air light, front corner light does not turn on.
2. The second switch turns on both front head light but rear tail lamp does not come on
3. When you tap on the brake, all tail light does come on (replaced with new bulbs)
4. Front and rear turn signal all work and all harzard lights are flashing fine
5. Check all engine bay fuse and driver side fuse and all are fine
6. Does have an alarm system that used to flash lights when arm and disarm and now there is no flash
So why is my rear tail light not coming on when I turn the light switch?
Any idea what the problem may be? Any help would be greatly appreciated.
Old Dec 19, 2006 | 06:25 PM
TheMuffinMan's Avatar
He knows where you live!
Did you replace with the right bulbs (dual filament?)
My guess is that the 2nd filament if you did isn't getting grounded somehow and have you checked interior fuses?
Old Dec 19, 2006 | 06:49 PM
Default Re: (TheMuffinMan)
Yes, I replaced it with dual filament and checked the interior fuse.
The-Kid
Dec 19, 2016 11:38 AM
dacohns7267
May 10, 2011 06:30 PM
Metal Typhoon
Oct 17, 2006 05:14 PM
