powersteering connector on obd1 engine harness
Old Jan 27, 2013 | 09:32 PM
speed_demon018's Avatar
Default powersteering connector on obd1 engine harness
ok so my title probably dont make since but anyway i put my engine harness on to my new engine and installed the engine and went to plug the powersteering connector back in and it has vanished. So i am trying to locate it and i need to know what collor it is and where it would be at on the harness. so if someone has a piture or diagram of what plugs into what that would awesome. Thanks
Old Jan 28, 2013 | 01:37 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: powersteering connector on obd1 engine harness
should be a green round two wire plug although I have seen them grey as well. What is your year make model and engine?
Old Jan 28, 2013 | 07:58 AM
its a 95 integra gsr
Old Jan 28, 2013 | 12:45 PM
wunfstgsr's Avatar
Loved
Community Favorite
lol look for it! it dont just run away. I have a 98 and mines is green i think, its probally tucked hidden somewhere back there just got to get down and dirty.
Old Jan 28, 2013 | 09:10 PM
But it did just run away ha-ha i looked for it
Old Jan 28, 2013 | 11:22 PM
i went under the car over car and am having no luck locating it i am actually quite confused
this will make me feel like an idiot but is the power steering connector on the engine harness or chassis harness
Old Jan 29, 2013 | 08:58 AM
This is irrating
Old Jan 29, 2013 | 12:13 PM
TurboJaxx's Avatar
if you go to the driver side fender, loosen your alternator so you can move it forward toward the engine, get flash light, follow the PS hose that comes from the pump and goes down youll see it..and if not looking from the bottom
Old Jan 29, 2013 | 08:41 PM
I know where it plugs in at i just can't find the connector to plug it in
Old Jan 30, 2013 | 12:51 AM
Technical Hero
What is your old engine and new engine? Can you take some pics of what connectors you plugged in to the new engine. Maybe you used that connector for one of the sensors. What is your year make and model as well?
Old Jan 30, 2013 | 06:00 AM
I marked all of the connectors prior to removing the harness from the engine
Old Jan 30, 2013 | 06:13 AM
TurboJaxx's Avatar
look from the bottom of the car, it should be under the intake manifold on the hardness (obviously) did you do a motor swap?
Old Jan 30, 2013 | 07:01 AM
Yes i did a motor swap and used my old harness and marked every connector just the powersteering one isnt any where to be found
Old Jan 30, 2013 | 07:58 AM
I found it. Its part of the chassis harness i had it taped up cause i wasnt going to use powersteering butthanks for trying to help
hannslebo
20
Jun 3, 2009 09:27 PM
cristegra09
May 7, 2009 12:23 PM
DB2NineDuece
Dec 6, 2008 09:07 PM
G0crxG0
May 2, 2006 06:25 AM
dingusjt
Aug 17, 2003 01:53 PM
