1998 pcm/ecm interchange w/1997
Old Jan 26, 2013 | 01:36 PM
lorenv3's Avatar
Default 1998 pcm/ecm interchange w/1997
ive got a 1997 civic and was wondering if the pcm/ecm was interchangeable with a 1998?
Old Jan 26, 2013 | 03:28 PM
grumblemarc's Avatar
The Grumpiest
Default Re: 1998 pcm/ecm interchange w/1997
What ECU specifically? Stop being vague.
Old Jan 26, 2013 | 07:07 PM
lorenv3's Avatar
electronic control module/drivetrain control module, computer or brain box for the car.
Old Jan 27, 2013 | 12:53 AM
HondaPartsHero's Avatar
Technical Hero
If they're the same ecu than yes
Old Jan 27, 2013 | 01:42 AM
holmesnmanny's Avatar
lol he wasn't asking you to tell him what ecu means he was asking you to tell him what kinds of cars(specifically) are you comparing
Old Jan 27, 2013 | 06:54 AM
The Grumpiest
No kidding.
What purpose do you have for wanting to exchange ECUs? As has been stated you can swap identical ECUs between each other.
If your thought is that you can simply swap an ECU from a car that's producing more power than your's is currently, then you're wrong.
Old Jan 27, 2013 | 07:29 AM
lorenv3's Avatar
it's a 1997 civic ex im getting code pcm internal circuit failure the dude down the street has a pcm he got from a junk yard off 1998 civic he didn't use, but doesn't know if it was an ex. They look and hook up the same and the first set of numbers match mine (37820) but the following # don't.
Old Jan 27, 2013 | 07:36 AM
The Grumpiest
Better.
List ALL of the numbers. Those don't help. You can only swap in a P2P. And it can only be a P2P from a 5-speed if you have a 5-speed, auto if it's an automatic.
http://hondata.com/techecuid.html
Technically you can run any ECU of the same OBD and it will start. Running well? Not so much. YOu can probably get away with a DX ECU but you won't have VTEC.
Old Jan 27, 2013 | 05:35 PM
lorenv3's Avatar
ok thanks a lot, i'll have to do a little junk yard shopping or try finding one on line.
g35silversurfer
Honda Civic (2001 - 2005)
26
Nov 7, 2016 11:23 PM
mita
Aug 28, 2014 11:46 PM
zenon8890
Mar 12, 2009 02:21 PM
slamdlude
Dec 27, 2008 11:48 AM
