overheating d16z
Old Jan 26, 2013 | 10:43 AM
Zen-civic's Avatar
Default overheating d16z
I live in the tropics so we took out the thermostat- don't need it. then we hooked up the fan to past the relay and just let it come on with the ignition. so the fans working, no thermostat to block flow, but it suddenly started to run hot. the gauge just showed it rising in heat. what else would cause this ?? help guys
Old Jan 26, 2013 | 10:50 AM
grumblemarc's Avatar
The Grumpiest
Default Re: overheating d16z
How about fixing the car to run like it was supposed to? With everything intact. No reason to run it otherwise.
Old Jan 26, 2013 | 10:56 AM
Former User's Avatar
Your engine needs a thermostat EVEN in the tropics.
Losing coolant?
Have you bled the cooling system or replaced the radiator or radiator cap?
Have you tested for a blown head gasket?
Old Jan 26, 2013 | 11:00 AM
92 civic ex 4dr's Avatar
The thermostat serves a purpose. Without it the fluid can move through the radiator too fast causing it to overheat, our can move to slowly causing it to run to cool.
Posted from Honda-tech.com App for Android
Old Jan 26, 2013 | 11:03 AM
delsolintegra's Avatar
Could be a bad radiator (cooling fins detached from the core).
Could be a blown headgasket (any bubbles in the overflow bottle at idle?)
Fast flowing coolants don't have time to absorb the engine heat.
When you remove the thermostat sometimes the block and head are cooler in one location (near thermostat housing) and hotter at the opposite side of the engine. This can cause warpage of the head and a blown headgasket.
1CiViC1
20
Dec 24, 2016 07:35 PM
fuglybutruns
Jul 28, 2015 07:50 PM
delsolnewkid
14
Feb 6, 2009 11:36 AM
spock_rocker
Jun 6, 2005 03:32 PM
dockersguy
Jul 23, 2004 09:01 AM
