Throw-out bearing in need of greasing....
Old Oct 20, 2002 | 07:11 PM
NONKonformyst's Avatar
Default Throw-out bearing in need of greasing....
My car recently started to make a chirping noise that goes away when the clutch pedal is depressed. I've come to realize that its the thowout bearing in the clutch assembly. My question for you guys is, what should I use to grease this? What things do I need to look out for when opening up the clutch assembly? Roughly, how long should this take myself and one other person? I've got the Helms so guide me, but personal experience would be appreciated. Thanks.
Old Oct 20, 2002 | 07:47 PM
Cottonwoodz's Avatar
Default Re: Throw-out bearing in need of greasing.... (95redLUDE)
Did you just get a clutch installed?
Old Oct 20, 2002 | 08:17 PM
bgod's Avatar
Default Re: Throw-out bearing in need of greasing.... (Cottonwoodz)
no point to grease it. just get a new one. you're gonna have to remove the tranny.
Old Oct 20, 2002 | 09:21 PM
Yeah, but I believe the Honda warranty is now expired. Instead of paying a **** load to have them do it I'm just gonna do it myself.
Old Oct 20, 2002 | 10:20 PM
Jonathan_ED3's Avatar
High Temp wheel bearing grease works good
Even if he does put in a new one, the new one would still need to be greased too. Either way, a good greasing is called for.
[Modified by hot_EG, 1:21 AM 10/21/2002]
Old Oct 21, 2002 | 02:43 AM
jc836's Avatar
Default Re: Throw-out bearing in need of greasing.... (hot_EG)
WHAT-throwout bearings are not greased in the field. They are either good or need replaced. We are talking about the bearing-not the fork or linkage here.
As was asked-did you just replace the clutch and not the bearing If so that iis your problem. You will have to take the tranny out to fix this.
Old Oct 21, 2002 | 05:27 AM
bgod's Avatar
Default Re: Throw-out bearing in need of greasing.... (jc836)
greasing the throw out bearing is just a temporary solution. you can however grease a new one before putting it in.
but either way, a new one is in order.
Old Oct 21, 2002 | 07:37 AM
BoostedH23a1's Avatar
Default Re: Throw-out bearing in need of greasing.... (bgod)
dont grease the surface that hits the clutch! just the pilot shaft. if u hear it its time for a new throw out. its only 40 dollars man
Old Oct 21, 2002 | 05:48 PM
2001se's Avatar
Default Re: Throw-out bearing in need of greasing.... (BoostedH23a1)
After you change it out, something to keep in mind: You can prevent wear on the throwout bearing if you don't leave the clutch pedal pushed down while you're waiting for long lights, etc.
Old Oct 21, 2002 | 07:07 PM
Like I said, I did just get the clutch replaced but I bet it is the same bearing. If it's making the noise then most likely it needs to be replaced, is that what you guys are saying? Does anyone have the part number by any chance? Thanks a lot for your replies, but how difficult is it to remove the tranny?
redman223
Mar 1, 2024 01:55 PM
TOAB
May 21, 2007 04:31 PM
maxogsr
Jun 22, 2005 06:46 PM
Flux
Feb 2, 2004 09:08 PM
AzntaggeR
Feb 18, 2003 06:01 PM
