99 CX HB - what would happen if I were to put high compression pistons in the D16Y7?
Old Jan 24, 2013 | 08:48 PM
99CivicCXEK's Avatar
Default 99 CX HB - what would happen if I were to put high compression pistons in the D16Y7?
So I'm rebuilding my D16Y7 in my 99 CX HB and am wondering what would happen if I were to put high comp pistons in it that would take compression ratio from 9.4:1 to 12:1. Also would I have to tune it differently?
Old Jan 24, 2013 | 08:53 PM
CO671's Avatar
Default Re: Increasing compression ration on a D16Y7
Old Jan 24, 2013 | 09:01 PM
doood's Avatar
been there done that
lol just stop
Old Jan 24, 2013 | 09:56 PM
98civdx's Avatar
Master Detailer
What would it take? A LOT, more then can even think of.
Re-tune? Oh yes.
Old Jan 25, 2013 | 12:36 AM
apexi_rsx's Avatar
You will bump the compression up causing you to run a higher octane and make no real power over 160hp on a stock or .5mm bore. and yes you would have to retune ... very costly for very little power u would gain. this is not a k20z1 or a2 that has vtec on the intake and exhaust cams. vtec on the single cam is like the weak vtec of a k20a3 and with a 2.0 is barely making 160hp and your 1.6 cant make enough displacement to make a 2.0 ltr. if u want more power out of a sohc ...boost it... and read up no one is going to spoon feed you... just point u in the right direction.
Old Jan 25, 2013 | 05:13 AM
jbpnoman's Avatar
12:1? Your sleeves are going to **** themselves.
Old Jan 25, 2013 | 06:24 AM
Former User's Avatar
Default Re: 99 CX HB - what would happen if I were to put high compression pistons in the D16
I think this questions has be adequately answered. /thread
Rooftop voter
Nov 2, 2008 10:01 AM
EM1OwnerSi
Oct 9, 2006 12:15 PM
J-HAWK
Feb 14, 2006 02:14 PM
Norcalstoppy
27
Aug 31, 2003 11:29 PM
Kronic
11
Jun 10, 2003 10:53 PM
