HELP!! my Honda civic SI 00 waste a lot of gas.
Old Jan 24, 2013 | 12:48 PM
wallendiaz's Avatar
Icon3 ...........
Old Jan 24, 2013 | 02:53 PM
apexi_rsx's Avatar
Default Re: HELP!! my Honda civic SI 00 waste a lot of gas.
your injectors have micro filters on them. which dont normally get plugged. you could try replacing them. also you can replace your cap and rotor on you distributor while your at it and set the ignition timing to spec with a timing light
Old Jan 24, 2013 | 03:02 PM
dirty19's Avatar
Ridin Dirty in Cali
Keep your foot out of vtec!
Old Jan 24, 2013 | 03:10 PM
grumblemarc's Avatar
The Grumpiest
How about more accurate numbers than just "I feel"? Go through a whole tank or two and get back to us.
Old Jan 25, 2013 | 04:14 PM
Mt3c's Avatar
25 Year Member
6 gallons for 100km is about 10 miles per gallon.
i would check for leaks around the fuel filter you just changed.
Old Jan 25, 2013 | 06:26 PM
PerfectionIsKey's Avatar
God dammit Dirty you think of the funniest damn things lol
Old Jan 25, 2013 | 09:30 PM
LadyCamouflage's Avatar
Now that's just too easy, yo.
Old Jan 26, 2013 | 09:00 AM
Former User's Avatar
Did you replace the spark plug wires and the distributor cap and rotor.
Did you check/adjust the ignition timing using a timing gun?
Old Jan 28, 2013 | 06:55 AM
dirty19's Avatar
Ridin Dirty in Cali
Dirty knows where the gas goes, when the vtec kicks in.
Ride that vtec hard till you hit redline yo, and its sucking the gas right out of the tank!
Old Jan 28, 2013 | 07:06 AM
VtecCivic93's Avatar
Originally Posted by wallendiaz
wait a minute.....mark in yellow on my gauge is miles or kilometers?????
Attachment 307962
Yes, that would be 100 miles.
If your getting 100 miles for 6 gallons, that is 16mpg and something is not right. You should be getting a lot more than that.
Old Jan 28, 2013 | 07:28 AM
slv104's Avatar
come on it should be that hard to figure it out, how do you drive, spirited? where do yo drive city or highway? if is city then 100 on 6 gallons is a little more than 16 miles to the gallon wich is right on the money if you drive with in the vtec zone, I had the same car no mods and I get 18 city 32 highway.
Old Feb 4, 2013 | 08:00 AM
slv104's Avatar
i just drive always in the city with air conditioner turn on, i never try to drive on highway and my rpm are always under 4,000 i never drive in vtec zone.
You just answer your question, city driving is the worse way to improve your gas mileage, your car is fine, 16 to 19 miles to the gallon is all you're going to get on city driving , if you want to tested fill up your tank and drive in the highway for about 30some miles and after that top off the gas again until is full don't keep adding after the the handle from the pump clicks, should be +/- a gallon.
Old Feb 4, 2013 | 08:07 AM
Patryk_98's Avatar
Here is something that is overlooked,
Do you let your car warm up at least 5 minutes before you start driving?
I'm not sure how cold it is out there but here in Chicago we have at least a foot of snow so I let my car heat up, I notice when I'm in a rush and I don't heat it up then it wastes alot more gas.
yanxu
12
Aug 8, 2010 09:57 AM
deemy72
Apr 20, 2009 06:50 PM
Its me DUB
May 2, 2008 06:58 PM
Jedi_Sol
Apr 22, 2005 12:11 PM
phantom grey eg
Feb 24, 2005 06:18 PM
