Turbo center section not sealing against exhaust housing
What the title says.
I had an el cheapo jdm sport t70 that started to leak a little oil into the exhaust. I took the turbo apart to try a rebuild, and where the exhaust meets the center doesnt stay tight. I am able to turn it to clock it without loosening the bolts. Did I forget a seal?
If the exhaust heat shield was removed and replaced, thats the problem. Check u get the same shield cause I just saw the same happen on a turbine and that was the solution.
Mag00n
May 9, 2004 04:59 PM
