Oxygen Sensor Code issue
Old Jan 22, 2013 | 08:18 PM
sinceasar's Avatar
Default Oxygen Sensor Code issue
1st time user to Honda Tech, thanks for helping. 1990 CRX SI stock Code 1 on check engine light. Replaced O2 sensor, noticed wire was broken going to connector that attaches to O2 sensor. Crimped connector to both ends, thus reconnecting the wire. Removed computer code (detached battery for 30 secs) and Car still throws Code 1. Engine not getting good power,like needing air, recent timing done and is right on, new plugs, wires, ICM, ignition coil, cap, rotor. Any ideas why code is still being thrown? Not a technician, just a 19 year owner of this vehicle.
Old Jan 24, 2013 | 04:07 PM
scottytee's Avatar
Default Re: Oxygen Sensor Code issue
Test continuity through the wire the might be another bad spot or a bad crimp
Old Jan 25, 2013 | 03:48 AM
~sp33~'s Avatar
EFB055
The sensor can also be tripped by lean/rich conditions. If the sensor has been tested to be working fine, check that any vacuum lines aren't cracked (particularly to the fuel map sensor) and that your sparkplugs/leads are decent.
Old Jan 25, 2013 | 04:17 AM
jlk16188's Avatar
any exhaust leak near the sensor will also trip it. removing the battery for 30 secs usually doesnt reset the ecu codes at least not on my cars
dbailey
21
Nov 9, 2007 07:08 AM
Eli Mac 67
Jun 8, 2007 02:30 PM
BAZ
Apr 26, 2004 01:45 PM
delSolLS
May 19, 2001 10:26 PM
