94 dx d16z6 swap + p28/Now cel 41 - o2 sensor?
Old Jan 21, 2013 | 06:31 PM
gmclb7's Avatar
Default 94 dx d16z6 swap + p28/Now cel 41 - o2 sensor?
Did a d16z6 swap on my 94 dx honda civic. Swapped in p 28 ecu and wired up the vtec. I am now getting a 42 cel. I looked it up and it is heated oxygen sensor. Motor came out of a delsol. Any ideas?
Old Jan 21, 2013 | 06:33 PM
Former User's Avatar
Default Re: 94 dx d16z6 swap + p28 Now cel 42 o2 sensor?
42 doesn't sound like a real code. Double check it (see codes sticky) or post a video.
Old Jan 21, 2013 | 06:52 PM
gmclb7's Avatar
Sorry I mean 41 Primary oxygen sensor heater
Old Jan 21, 2013 | 06:56 PM
Default Re: 94 dx d16z6 swap + p28/Now cel 41 - o2 sensor?
If you reset the ECU, does the code return?
Did you have to rewire the o2 sensor plug for the swap?
Old Jan 21, 2013 | 06:57 PM
gmclb7's Avatar
It will turn back on after a few minutes of running. Plugged right up during swap.
Old Jan 21, 2013 | 07:01 PM
Make sure the O2 sensor connector is fully seated. If so, start by testing whether the Yel/Blk wire in the unplugged connector gets battery voltage with the key in ON(II).
Old Jan 21, 2013 | 07:32 PM
gmclb7's Avatar
Appreciate the help. I will check and test tomorrow.
Old Feb 10, 2013 | 11:09 AM
97Cummins's Avatar
What ended up causing the problem you were having? I just swapped a Z6 into a VX and it has the same code coming up.
Old Feb 10, 2013 | 01:14 PM
94EG8's Avatar
Seagull Management
Did you do the VX O2 sensor fix?
Old Feb 10, 2013 | 04:53 PM
97Cummins's Avatar
I'll give that a try tomorrow. I hadn't seen it before. I have the original Z1 engine harness on my Z6. Will this still work?
Old Feb 10, 2013 | 05:21 PM
94EG8's Avatar
Seagull Management
IIRC it will.
Old Feb 11, 2013 | 11:51 AM
delsolintegra's Avatar
When you handled your exhaust manifold during the swap you didn't create a hairline crack just right of the O2 bung hole did you? This is where they commonly crack and it will cause a code 41 CEL. It happened to my 93 del sol (not during a swap) and I replaced the manifold with a cheap set of headers. I've since learned it's a common problem.
Cataclysmic
11
Aug 3, 2009 01:57 PM
Manolo
23
Aug 16, 2007 07:00 AM
DelSolDon
Jun 19, 2007 02:26 PM
4DRB16A
11
Apr 8, 2005 12:50 AM
incognitoracerr
Sep 25, 2003 02:45 PM
