97 civic dies after a 3hr drive as im getting off freeway
Old Jan 21, 2013 | 04:35 PM
dearcrystal's Avatar
Icon2 97 civic dies after a 3hr drive as im getting off freeway
i was driving about 250 miles one way and everything was fine it ran fine then i turned off the car and it wouldnt start my battery was fine my alternator was fine i went and got them tested. i jumped the car and it started right up.
then on the way home it just died getting off the freeway on the exit. i got towed to a parking lot and called my dad thinking i needed a jump and it just started. he litterally just touched the starter and it started he has no clue what he did. it only does this on long drives. its a manual tranny.
i just really dont know whats going on
Old Jan 21, 2013 | 05:46 PM
Former User's Avatar
Default Re: 97 civic dies after a 3hr drive as im getting off freeway
After the engine dies, does the starter fail to crank the engine or is it a cranks but won't start problem?
Old Jan 22, 2013 | 01:38 AM
eghatch9295's Avatar
Stancetard Hate Monger
could be the start of a coil crapping out
Old Jan 22, 2013 | 07:27 AM
it doesnt crank, turn over, it doesnt even click.
Old Jan 22, 2013 | 07:52 AM
Clean and tighten the G3 transmission ground at both connections on the transmission and chassis. Do the same for battery connectors and the G1 battery ground attached to the chassis.
Old Jan 22, 2013 | 08:21 AM
Erdinc Akay's Avatar
I once saw in a TV-Show that a Mercedes had a similar problem and that they had a hard time finding out what it was.
After hours they found out, that it was that sensor, that tells the ECU, that the engine is actually running. It seemed like it was damaged and couldnt handle the engine-heat anymore.
I dont know if Hondas have that sensor, but if they do, i would check it!
Old Jan 22, 2013 | 12:49 PM
def. not coil. if you're checking grounds, check the thermostat one as well.
Old Jan 22, 2013 | 12:51 PM
If only G101 is disconnected, then the engine won't start but it will crank. Nonetheless, it's still worth checking.
Old Jan 30, 2013 | 11:26 AM
I've noticed that the idle gets real low about 0-500 rpms after i slow down from being in 5th gear which could just be quicidental. i was driving on the freeway and the idle basically wasnt there so i had to keep the rpms up so it wouldnt die on me
so im thinking tps, or idle air control.
rc.square24
Mar 18, 2013 11:54 PM
JDM_95_LS
17
May 24, 2011 07:43 AM
JDMdb8isO
Feb 6, 2011 12:58 PM
silentkid
Mar 3, 2010 11:59 AM
SOKDO
Jun 2, 2005 10:33 AM
