Is this oil feed set-up okay?
Old Jan 20, 2013 | 11:49 AM
thatcivic96's Avatar
Default Is this oil feed set-up okay?
I have everything in the picture marked, not the best job in the world at marking it all in Paint, but there it is. The feed line to turbo is 30" long, the line to the block is 12" long and it is a brass block with 4 ports, one to the block, one for OEM sending unit, one for the aftermarket gauge sending unit, and one for feed line to turbo. All lines are -3an. I will run a restrictor at the turbo but that is not the point of this thread. I am curious if the 12" long from block to brass piece is too long? I will securely mount it to the fire wall or where ever I see fit. Any opinions?\\
Old Jan 20, 2013 | 11:53 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: Is this oil feed set-up okay?
what picture?
Old Jan 20, 2013 | 11:55 AM
That would be good to include, I added it.
Old Jan 20, 2013 | 12:08 PM
wantboost's Avatar
Who is Mr Robot?
that looks good, remote mounting the senders insures the fitting wont snap off the block, however why keep the stock sender? it doesn't do anything, doesn't supply the ecu with pressure readings, etc.... its only purpose is to cut on the idiot light when pressure drops to zero... ditch it
Old Jan 20, 2013 | 12:11 PM
That was my curiosity, but I was not 100% sure if it would cause any trouble my ditching it. I guess it makes sense to just block that port off since I can just monitor pressure with the ProSport gauge I have.
Old Jan 20, 2013 | 12:13 PM
So the 12" line is not too long to lose any pressure?
Old Jan 20, 2013 | 12:20 PM
wantboost's Avatar
Who is Mr Robot?
with small line like that, you won't lose any pressure
people run ls/vtec oil lines, turbo feed, remote filter, and an oil cooler without pressure drop issues
alex1320
Dec 18, 2012 04:57 PM
huge230
Nov 3, 2007 09:58 AM
vladd
Sep 21, 2006 07:54 PM
Tad
Jan 2, 2006 03:15 PM
reignofchaos
Aug 3, 2003 10:24 PM
