Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
1999 Odyssey CEL / Rough running
Old Jan 20, 2013 | 02:00 AM
evantess25's Avatar
Default 1999 Odyssey CEL / Rough running
Hello - I have a '99 Odyssey with 190K miles. CEL came on some time ago but van ran fine. Yesterday noticed oil was a little low and added about 1/3 quart of oil and drove van with no issues. Later in the day it started rough and CEL started flashing and then went solid and continues to run rough. Any thoughts? Thanks.
Old Jan 20, 2013 | 10:06 AM
evantess25's Avatar
Default Re: 1999 Odyssey CEL / Rough running
Hello - I just drove to Autozone and they downloaded the following codes from my 1999 Odyssey: P0300, P0301, P0303, P0304, P0306, P1399, P1457. Technician at store thought it may be the MAF sensor since he had similiar experience. Thoughts?
Thanks.
Old Jan 20, 2013 | 03:16 PM
Myroslav69's Avatar
You have misfire on all 6 cylinders. When was the last time you did a tune up? New plugs? Filters? If you are going to buy plugs for it buy ONLY Nippo Denso or NGK!! These are OEM Japanese plugs that work the best in a Japanese engine. The P1457 code is for EVAP canister, either the solenoid is bad (most likely) or you have a leak in the hose. Its nothing major, does not affect the way the engine runs, but should be fixed.
drb53
Honda Fit
Jun 2, 2017 03:30 PM
audi_nicoya209
Sep 14, 2016 01:22 PM
Amused
Jan 11, 2007 10:39 AM
VegasVTEC
Oct 23, 2004 02:08 PM
Drag-On23
Feb 10, 2004 09:48 AM
