car wont start... raipid clicking HELP!!!
Old Jan 19, 2013 | 11:18 AM
dsm duster's Avatar
Default car wont start... raipid clicking HELP!!!
i have a 94 hatch and my car wont start all i hear is a rapid clicking noise. my battery is still strong, and i have cleaned my battery terminals and cleaned my connections to the starter but it still does it. so i guess my question is could my started possibly be bad and what else could cause this?
Old Jan 19, 2013 | 11:19 AM
grumblemarc's Avatar
The Grumpiest
Default Re: car wont start... raipid clicking HELP!!!
Rapid clicking from where and when?
Old Jan 19, 2013 | 11:21 AM
dsm duster's Avatar
i think its coming from under the hood somewhere but its hard to tell by myself.
Old Jan 19, 2013 | 11:24 AM
jbpnoman's Avatar
Remove the starter and bench test it. You'll need a car battery, jumper cables, and a small length of speaker wire or similar.
Attach the negative ends of the jumper cables to the battery, as well as to the body of the starter. Where the bolts go is a good place.
Attach the positive ends of the cables to the battery, as well as to the main power lead on the starter.
Make sure you brace the starter, and keep the area in front of the starter gear COMPLETELY CLEAR. You can either brace it in a vice, or just stand on it.
Use the small length of speaker wire to connect the power terminal on the starter to the signal terminal. The starter gear should rapidly shoot out and spin. If it doesn't, the starter needs to be replaced. If it does, that isn't the problem.
Old Jan 19, 2013 | 11:45 AM
Former User's Avatar
Sounds like a dead battery to me. What voltage do you measure across the two battery posts?
Old Jan 19, 2013 | 12:49 PM
Black R's Avatar
25 Year Member
Solid advice.
It might also be the starter relay.
Old Jan 19, 2013 | 01:01 PM
beecee18's Avatar
Originally Posted by RonJ@HT
Sounds like a dead battery to me. What's voltage do you measure across the two battery posts?
This^^^
I must comment on OP's screen name, Love it.
My first car was a duster 340, lol
Old Jan 19, 2013 | 01:03 PM
jbpnoman's Avatar
I was giving the OP credit that he knew how to test the battery, and isn't just saying he did. Hopefully I'm not wrong.
Old Jan 19, 2013 | 02:30 PM
A bad starter relay is extremely rare for our Civics.
Old Jan 19, 2013 | 03:44 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Here is a quick DIY to test your starter circuit: https://honda-tech.com/forums/showth...=fcm&t=2961164
Old Jan 21, 2013 | 05:59 AM
ameer_vtec99's Avatar
agreed
it might be the starter or the battery
Old Jan 21, 2013 | 07:11 AM
JuggerNaut-CTR's Avatar
Check the postive post is clean and on tightly...
Old Jan 21, 2013 | 02:22 PM
dsm duster's Avatar
I tested the starter and it worked all i did was go around and clean up all my grounds and it starts now. Thanks for all the advice i really appreciate it.
egtony
May 18, 2009 09:58 AM
lilsol89
Jan 5, 2009 03:57 PM
DeleriouS25
Oct 1, 2008 06:40 AM
ThaSpitefulWun
19
Oct 5, 2004 12:14 PM
See Are X
Mar 6, 2003 10:08 PM
