Modifications needed to fit ITR bpipe on EG?
Old Oct 20, 2002 | 04:22 PM
Toda Party's Avatar
Default Modifications needed to fit ITR bpipe on EG?
93 DX hatch with an LS swap. DC header, testpipe, and tanabe racing medallion. i want to switch to something more quiet, such as the itr exhaust...
anyway, i've heard something to the effect that the bpipe is too long??
Can someone explain what the differences are ? thaks
Old Oct 20, 2002 | 05:24 PM
chap99cvc's Avatar
Default Re: Modifications needed to fit ITR bpipe on EG? (Toda Party)
I'm also interested in the answer to this question!
Old Oct 20, 2002 | 06:28 PM
Gump's Avatar
the b-pipe is to short, you have to cut and lengthen it about two inches, or you can get the ITR exhaust manifold, and cat, with those two parts you don't have to cut.
Old Oct 20, 2002 | 07:14 PM
Rratedcivichatch's Avatar
Default Re: Modifications needed to fit ITR bpipe on EG? (Gump)
i had about the same question... i have a type r swap on a 95 cx. with dc sport headers, would the stock type r exhaust fit on mine? my exhaust is currently too loud for my taste , so i would like to get somehting very quiet without restricting the engine itself.
Old Oct 20, 2002 | 09:39 PM
Gump's Avatar
Default Re: Modifications needed to fit ITR bpipe on EG? (Rratedcivichatch)
b-pipe will fit, but the muffler will not unless you have cut and modified
Old Oct 26, 2002 | 04:50 PM
Toda Party's Avatar
yeah thatexactly why i was itnerested.
thanks for the help gump...
also, i was told the exhaust hangers face the wrong way??
Old Oct 26, 2002 | 05:39 PM
netnutshatch's Avatar
I just recently encountered this same problem on my 92 CX. The hangers on the b-pipe line up just fine, but in my case a 4.5" extension was needed to connect to the cat. I have a 99 GS-R header and cat. I am under the presumption with an ITR header and cat the b-pipe will in fact bolt right up. Here is mine:
[Modified by netnutshatch, 9:40 PM 10/26/2002]
Old Nov 9, 2002 | 08:02 PM
Toda Party's Avatar
Default Re: Modifications needed to fit ITR bpipe on EG? (netnutshatch)
do u have any more pics?
Old Nov 12, 2002 | 09:57 PM
Toda Party's Avatar
just to update this for future "searchers"
on my setup, with DC header and i think a random tech cat, the bpipe was short by 2 inches like gump said
i couldn't fit the ITR axleback due to my sway bar being there, i can't tell for sure if the actual can would fit because even if the sway bar wasn't there, it still would've been a little tight
shrug
Old Nov 12, 2002 | 10:06 PM
mantic6t9's Avatar
Kinda OT but...
I'm getting the t1r b-pipe and spoon n1 axle back for my hatch. When i get my gsr or typeR swap will i have problems with the exhaust?
Old Nov 12, 2002 | 10:21 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
itr mani / cat / b-pipe works fine, hangers and all. the axle back is the problem. my GReddy SP EH3 axle-back needs to get lengthened about an inch and the flange flipped 20 degrees or so.
oh, you can't hear the car 1/3rd of a block away at 7-8k rpm.
*shrug*
Old Nov 12, 2002 | 10:25 PM
deviant1's Avatar
Default Re: Modifications needed to fit ITR bpipe on EG? (SkyeC)
what about EK hatches?
Old Nov 12, 2002 | 11:17 PM
function83's Avatar
Default Re: Modifications needed to fit ITR bpipe on EG? (C5_ALLMOTOR)
alright
i got a tanabe integra gsr b pipe, itr straight pipe(cat), and itr header.
im assuming this will work.
which axle back muffler do i use on the 94 hatchback?
use any axle back for a 92-95 hatch. just take everything to a muffler shop and have everthing modified to fit. such as adding or modifying existing flanges.
[Modified by djhatch, 8:17 AM 11/13/2002]
Old Nov 13, 2002 | 12:40 AM
ill phil's Avatar
Yeah its not too loud with a good resonator.
My set up is DC JDM 4-1, Carsound Cat, Integra B-Pipe. All fit perfectly to stock hangers. I did have to get a custom axleback though, but I wanted a magnaflow so it was all good.
myronwong
Apr 29, 2008 06:18 PM
myronwong
Apr 28, 2008 08:52 PM
vietfella
Dec 24, 2006 01:54 AM
absolut b18
Jun 14, 2003 04:41 PM
project 9
Dec 2, 2001 02:41 PM
