b18C1 Turbo needs help.....!!
ok so i have a built b18c1 turbo, pretty clean built no check engine light..compression is 9;1 the way it was built, is tuned on a s300 by raceline here in socal, the motor ran fine boosted up to 18 lbs, untill one day it all of a sudden started cutting out at about 5000 rpms almost like a boost cut out.... so i putted the car around for about a week untill one day the car started bogging almost like i was running out of fuel, then it just cut off and hasnt started for about a week, had the whole msd external coil and the cap and rotor but ive herd that they are know for going bad, so i switch to a new stock gsr dizzy. but still no start, i change the plugs, the wires, and no change, the motor cranks just no start, i took off the screw from the top of the fuel rail and im getting fuel and i can hear the fuel pump kick on. not sure sure if mybe the 1000cc rc injecters arent working not sure how to check. please if u have any suggestions please lmk, kinda scared to take it to a shop and get screwed over when it could be an easy fix...
DC2NING
Sep 5, 2006 02:00 PM
93civciv
Nov 4, 2005 07:43 PM
jdmciviceg
May 14, 2002 10:11 AM
