93 civic ex ECU
Where can I get an OBD1 for my 93 civic coupe? it has in a d16z that i got from a civic del sol. It runs fine but i've been getting a code 13 which is an "atmospheric pressure sensor" and everyone has been telling me thats found inside the ecu so i better just get a new one. Where could i order one and have it shipped to Belize?that's in Central America. By the way, this also causes or gives me a hard time to start on rainy and cold days. it takes a long time before the fuel pump primes. it wont start until you hear that click sound from the main relay.
I heard it's usually the capacitor at location C14 on the ECU circuit board that is the problem for the crank but no start because the fuel pump doesn't prime problem. I have a ECU with that problem and I'm thinking about getting it repaired by a good solderer to confirm this solution.
Someone else suggested to get all the capacitors swapped out on the board because they are all subject to moisture and heat deterioration over 18 to 20 years.
It's a common problem and seen a lot on these threads.
whiteheadk62
15
Jul 23, 2014 05:19 AM
Cuda 426
21
Jul 5, 2014 08:26 AM
guitarma
Sep 26, 2011 12:46 AM
delsolintegra
Jun 29, 2011 08:06 AM
