1994 Honda Accord EX Coupe Driver side Window issue
Old Jan 17, 2013 | 09:58 AM
faran's Avatar
Icon2 1994 Honda Accord EX Coupe Driver side Window issue
Techs-
Driver side power window on my 1994 Coupe (A/T) EX Accord is causing me trouble and issue.
When it's cold outside, I can barely bring it down or up.
If I use some PB Blast or WD-40, then window starts to go up and down, else I hear click-click sound and have to manually put pressure on the glass to bring up and down, while holding the power window button.
Any cheap or DIY fix would be appreciated?
P.S: Don't want to buy any parts or anything.
Old Jan 17, 2013 | 10:08 AM
kidcool1977's Avatar
SHAME ON YOU REBECCA!
Community Builder
Default Re: 1994 Honda Accord EX Coupe Driver side Window issue
apply silicon paste around the window channels. It's kinda pricey (25.00) and since you will likely use it once find a mechanic that has some and see if they will apply it for you for 5 bucks.
this video explain what I mean, skip to 14:00
http://www.youtube.com/watch?feature...v=D1svF3Pmolc#!
Old Jan 17, 2013 | 10:13 AM
TheMuffinMan's Avatar
He knows where you live!
Originally Posted by faran
Techs-
You don't want to buy any parts or anything and expect it to be magically repaired?
What you want is ShinEtsu grease for the rubber portions of the windows. Stop spraying WD-40 and PB Blaster on it, you're going to ruin the rubber.
Get the ShinEtsu grease from your local Honda dealer, use that to clean up the rubber trim all around the window.
Then take off the door panel and clean all the gunk out of the tracks. Use white lithium grease for the metal tracks.
Old Jan 17, 2013 | 10:42 AM
Fitz Williams's Avatar
10 Year Member
The best fix is a new gasket around the window.
Old Jan 17, 2013 | 10:54 AM
faran's Avatar
Thanks so much guys.
What I meant, don't want to buy any EXPENSIVE parts
One of the mechanic actually told me to use PB or WD-40
When you say rubber trim, you mean the channel in which glass slides up and down?
If I use silicone spray, do you think that would be helpful and useful?
I found this link pretty helpful:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/slow-power-windows-2357164/
Old Jan 17, 2013 | 11:00 AM
https://honda-tech.com/forums/showthread.php?t=2357164
Note that post #20 mentions ShinEtsu as well
Rubber trim = all around the inside of where the window rolls up and down. So roll the window down, then grab the ShinEtsu and a rag and liberally apply. Dig your fingers into the window channel and rub the grease in until it goes clearish (it's white/cream colored from the tube). It's recommended for the S2000 guys to lubricate and refinish their convertible top moldings - you can safely apply it around your rubber door seals too to get some better sealing from them and rejuvenate them.
That alone may help. I'd also still take apart the door panel and clean the metal tracks.
Regarding PB Blaster on them:
Use caution when using PB on: plastics, paint, rubber*, fiberglass, belting and similar materials. Always apply to an inconspicuous area before proceeding with application as PB may stain such surfaces.
*The petroleum solvents in PB will impregnate common black butyl rubber. If left in contact with these materials for extended periods of time they will begin to swell and deteriorate
http://www.blastercorporation.com/PB_Blaster_FAQS.html
Old Jan 17, 2013 | 11:08 AM
faran's Avatar
I have seen your posts everywhere, you are famous for a reason
Yes, I found this link helpful after you advised:
http://s2000.com/forums/interior-aud...shin-etsu.html
Metal tracks will be needing White Lithium grease, right?
Any recommendation for Silicone lube spray, since I have it already. Else, need to buy shin-etsu?
I appreciate your help and response Muffin Man
Old Jan 17, 2013 | 11:42 AM
Community Builder
I used the silicon paste and I haven't had any issues since, and since you want the cheapest method I propose you find a mechanic with silicone paste in their arsenal of lubricants and give him 10 bucks.
The honda grease is also pricey, matter of fact I have a tube here that I never use if you want pay the shipping and it's yours.
Old Jan 17, 2013 | 12:21 PM
faran's Avatar
I am going to go with shin-etsu or silicone lube grease option.
It has a lot of good information:
http://www.hondaaccordforum.com/foru...e-paste-41557/
Will let you know the outcome of it, thanks again guys!
Old Jan 17, 2013 | 03:51 PM
faran's Avatar
Alright guys, I have cleaned those channels well, with lil bit rubbing alcohol and then used CRC Silicone Based Lubricant.
So far, I am really pleased with the results, not sure how many days it will last
Windows are going up and down like a charm
trublu006
Sep 12, 2017 07:04 PM
Cisco XO
Jul 17, 2017 02:32 PM
MaJoR_02
Jul 1, 2014 07:47 AM
