PTE 6768, 14 psi on F20c
Old Jan 16, 2013 | 07:48 PM
turbociv910's Avatar
Default PTE 6768, 14 psi on F20c
Hit the dyno this week to get a tune from Carolina Dyno on their Superflow dyno.
Modifications/Specs:
-Custom Sidewinder kit by Carolina Dyno
- 4" Custom Stainless exhaust by CD
-Stock Engine/drivetrain/stock hg
-ACT 6 puck sprung HD
-Bosch Motorsport 1000cc injectors, Custom top hats.
-400lph
-93 octane
Cant wait to see what it does on e98!! Tuned on AEM EMS v2!!
Old Jan 16, 2013 | 09:08 PM
TheShodan's Avatar
Moderator
Default Re: PTE 6768, 14 psi on F20c
Boy, that turbo is a lazy boy. Full pressure came in VERY late.. But for that large of a turbo, its to be expected.
Old Jan 17, 2013 | 04:40 AM
LightningTeg's Avatar
Community Builder
Why a 67 for a sub 500whp build? You could do the same and have much larger powerband with something like a 6262 and still have room for ALOT more
Old Jan 17, 2013 | 05:36 AM
TheShodan's Avatar
Moderator
Or even smaller with a nicer powerband..
Old Jan 17, 2013 | 05:42 AM
portenio78's Avatar
Upgrade your fuel if going for bigger numbers on e98.
Old Jan 17, 2013 | 07:54 AM
A lazy turbo is defined by ones own opinion. Its leaving room on the table for more boost when the time comes.
It will be a 3:2 toluene mix. It raises the stoich ratio needing less fuel compared to straight E.
Old Jan 17, 2013 | 08:11 AM
kbouchard1092's Avatar
Originally Posted by turbociv910
Its leaving room on the table for more boost when the time comes..
You're leaving alot on the table; thats for sure. Much more then those injectors/stock block can support.
Nice Car tho!
Old Jan 17, 2013 | 08:52 AM
TheShodan's Avatar
Moderator
Interesting response. Not much of a convincingly-logical argument, but interesting..
Old Jan 17, 2013 | 09:27 AM
riceball777's Avatar
Sure is laggy. Very poor powerband. Poor turbo for straight pump gas. But if u plan to run e98/race gas then u can turbo up the boost and make twice the power I suppose as long as you have the fuel syster for it.
integraboosted
Feb 12, 2007 10:47 AM
D@nnY
Mar 15, 2005 02:16 PM
xstalkrx
Mar 18, 2003 01:55 PM
M.A.R.C.
Mar 9, 2003 03:28 PM
Arturbo
Oct 30, 2002 08:34 PM
