Honda CR-V & Element 2WD & 4WD Element & CR-V
b20b 7800 rpm
Old Jan 16, 2013 | 02:22 PM
jestin91's Avatar
Icon2 b20b 7800 rpm
hey guys i have a b20b with a gsr tranny the motor is from a auto trans in japn but i was having fun with it so i didnt get it in fourth all the way and it reved all the way to 7800 should be worried this is the third time its happen
Old Jan 16, 2013 | 02:40 PM
jestin91's Avatar
Default Re: b20b 7800 rpm
b20b
Old Jan 16, 2013 | 02:44 PM
93CRX-Del SOl's Avatar
you shouldn't get into a habit of it, you should try and keep it under 7500 rpm
as far as your engine being ok, if you don't hear or feel anything different, I wouldn't worry about it
Old Jan 16, 2013 | 03:05 PM
LDForget's Avatar
yeah...ive hit 8 grand a few times by accident (keep forgetting i removed the rev limiter, lol), but try to keep it under 6250 which is the stock redline.
Old Jan 16, 2013 | 03:47 PM
jestin91's Avatar
Yea I haven't took to 8grand but the motor is pretty strong or are they weak
Old Jan 16, 2013 | 06:10 PM
jestin91's Avatar
bump
Old Jan 17, 2013 | 06:06 AM
shermanyang's Avatar
The motor is strong but there are 'weak' components. spinning the motor that fast most likely you'll float a valve or break a rod bolt. change out the valve springs for dual valve springs and rod bolts for arps and you can spin it to 8k all day.
Old Jan 17, 2013 | 11:18 AM
LDForget's Avatar
Stock redline is 6250, keep it below that.
Old Jan 17, 2013 | 07:41 PM
rus_boi's Avatar
make sure all the parts are balanced and put together properly and good tune and you COULD be good =P
Old Jan 18, 2013 | 11:37 AM
94dbteg's Avatar
really? b20b and b20z must have a different redline because mine is 6700 or so.
Old Jan 18, 2013 | 12:39 PM
LDForget's Avatar
I'll Take a picture after work. Fairly certain it's 6250
Old Jan 18, 2013 | 04:50 PM
LDForget's Avatar
GsrDc2
Apr 16, 2008 04:52 PM
hondaeg8
16
Dec 4, 2005 10:33 AM
Hatch It
May 19, 2004 01:27 PM
Wo-Nelly
Feb 1, 2004 07:42 PM
JChops
15
Oct 12, 2003 09:47 AM
