Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Brake problem
Old Jan 16, 2013 | 01:27 PM
Hawkman13's Avatar
Default Brake problem
Hey guys I have a 2003 Accord V6 coupe and I've been having a problem with my brakes. They weren't working to we'll so I bleed the front brakes and then they were like a new car again. Now about 2 weeks later there back to the way they were. I love this car but I've had more little issues with this car than any other car I've ever owned. First the valve cover gasket went, then the power lock actuator, then the starter, then the airbag light, then the CD player, now there's a clicking noise and I have no idea where it's coming from. But anyway. I'm guessing the master cylinder is going bad and before I replaced it I wanted to see if anyone else has had this problem and if it could be anything besides the master cylinder.
Old Jan 16, 2013 | 07:29 PM
BLKFLSH's Avatar
Default Re: Brake problem
Check for leaks, then bleed the rear brakes. If when you are sitting at a stop (in Drive), the brake pedal sinks to the floor, you either have a leak, or a bad master cylinder. Has your brake fluid ever been changed/flushed? It's way past due, if you haven't. It should be done every 3 years.
bigrob119
Oct 18, 2009 04:02 PM
pedroa06
Sep 3, 2009 06:23 PM
96 GSR-T
Jun 10, 2008 07:31 PM
MrEg
Sep 22, 2003 04:49 PM
2camsaam
May 12, 2002 07:02 PM
