Brake problem
Brake problem
Hey guys I have a 2003 Accord V6 coupe and I've been having a problem with my brakes. They weren't working to we'll so I bleed the front brakes and then they were like a new car again. Now about 2 weeks later there back to the way they were. I love this car but I've had more little issues with this car than any other car I've ever owned. First the valve cover gasket went, then the power lock actuator, then the starter, then the airbag light, then the CD player, now there's a clicking noise and I have no idea where it's coming from. But anyway. I'm guessing the master cylinder is going bad and before I replaced it I wanted to see if anyone else has had this problem and if it could be anything besides the master cylinder.
Re: Brake problem
Check for leaks, then bleed the rear brakes. If when you are sitting at a stop (in Drive), the brake pedal sinks to the floor, you either have a leak, or a bad master cylinder. Has your brake fluid ever been changed/flushed? It's way past due, if you haven't. It should be done every 3 years.
96 GSR-T
06-10-2008 07:31 PM
2camsaam
05-12-2002 07:02 PM
