Rebuilding engine, do I have all the necessary parts?
Old Jan 16, 2013 | 01:03 PM
qqhorus's Avatar
Default Rebuilding engine, do I have all the necessary parts?
I'm rebuilding my '98 B18C. This is an OEM rebuild but I was wondering if I had all the necessary parts for the rebuild.
15100-P72-A01 - PUMP ASSY., OIL
14400-P72-014 - BELT, TIMING (126RU26)
14510-P30-003 - TENSIONER, TIMING BELT (KOYO SEIKO)
12251-P30-014 - GASKET, CYLINDER HEAD (NIPPON LEAKLESS)
15221-PW0-S01 - GASKET, OIL STRAINER (OIL PICKUP GASKET)
19200-P72-013 - WATER PUMP (YAMADA)
19301-PAA-306 - THERMOSTAT ASSY. (NIPPON THERMOSTAT)
91214-PLE-003 - REAR MAIN SEAL OIL SEAL (80X100X10) (NOK)
91213-PR3-004 - OIL SEAL (29X43X8) (ARAI)
12513-P72-003 - PLUG, CYLINDER HEAD
I'm buying a Hondata IM gasket, Felpro oil pan gasket so those aren't listed with OEM part numbers.
Also the pistons, piston rings will have to wait until I see how much my block needs to be bored.
Thanks for the help!
Old Jan 16, 2013 | 01:14 PM
qqhorus's Avatar
Default Re: Rebuilding engine, do I have all the necessary parts?
Forgot to add headstuds will either be OEM or ARP. Whichever my machine shop guy can get cheaper.
Old Jan 16, 2013 | 03:07 PM
95BG33PGSR's Avatar
Main bearings and main/ connecting rods bolts/studs
Old Jan 17, 2013 | 04:12 AM
qqhorus's Avatar
Knew I was forgetting something! Thank you sir!
Old Jan 17, 2013 | 12:47 PM
IN VTEC's Avatar
Camshaft seals, VTEC solenoid filter/gasket, oil pump o-ring, Valve cover gasket set with grommet-washers and spark plug gaskets, distributor o-ring, exhaust-side camshaft plug - recommend an aftermarket one.
...and can't forget Hondabond HT
Old Jan 18, 2013 | 11:22 AM
qqhorus's Avatar
Thanks sir!
Stacygifford
Jan 28, 2014 06:14 PM
raverx3m
Dec 27, 2011 02:13 AM
3rdGteg
Sep 27, 2002 05:56 AM
schwett
Apr 24, 2002 08:37 PM
