B20 crank pulley w/ integra PS +AC?
Old Jan 15, 2013 | 08:53 PM
mreed's Avatar
Default B20 crank pulley w/ integra PS +AC?
Hey guys, im using the b20 crank pulley in my b20 swap with the integra ps mount and integra AC components and im wondering if anyone else has done this on their b20 swap, and if so what size belts did you use? i got CRV belts but they are too small even at the lowest tension. Any insight would be helpful.
Old Mar 11, 2019 | 09:47 PM
davidg305's Avatar
Default Re: B20 crank pulley w/ integra PS +AC?
Hey man did you ever figure this out I’m literally in the same boat. I don’t want to swap over the ls crank unless on have too. Did you ever figure out what belts you need!
Old Mar 11, 2019 | 10:47 PM
MotorMouth93's Avatar
10 Year Member
Just use your B18 crank pulley on the B20.
Old Mar 11, 2019 | 10:55 PM
davidg305's Avatar
but do the lines on the b18 crank pulley match up to the same as the b20. When I change the crank pulley won’t that effect the timing? Would I just make the motor tdc and then match the lines on the b18 crank to where they were when I removed the crank off the b20.
Old Mar 11, 2019 | 11:54 PM
bigjon1378's Avatar
i would stick with the b20 pulley because it is sized for the motor and ideal for the engine dampening, if it is a jdm b20 pulley then just use a slightly bigger belt then 97-01 crv calls for because the jdm pulley is slightly larger, if it is usdm just use 97-01 crv belt sizes. either way crv belt will probably work for both pulleys
Old Mar 12, 2019 | 08:04 AM
10 Year Member
The B18 crank pulley will fit just like the B20 pulley, both cranks are keyed the same way and both pulleys have the same timing marks.
In theory, you are correct. The reality is though that people have been mixing and matching B-series crank pulleys for years with no problems.
If the CR-V belts will work though that's probably the best option.
Old Mar 12, 2019 | 02:57 PM
davidg305's Avatar
Yea it’s a 99 jdm b20b high comp getting swapped into a 99 integra gs. So you think I should just stay with the b20 pulley? I can always take it off the car later but I just can’t get a straight answer from anyone that is running a b20. I wanna keep ps and ac but not sure how I’ll ever know what belts I’ll need. Let alone will the alternator belt work?
Old Mar 12, 2019 | 03:29 PM
Chrisfrom1986's Avatar
Just get longer belts. Learn how to read them and then go to the store and get the right one. I used a d16y8 power steering belt for my alternator on my B20 swap. It's really simple to find the correct length, look at the type of belt, measure the width and count the ribs. Has none of that occurred to you?
Old Mar 12, 2019 | 04:52 PM
davidg305's Avatar
lol it has occurred brother and thanks for the help. I just assumed that they’re would be more people that have swapped a b20 into an integra and knew already. Believe me I swapped a b18c1 into an ek 12 years ago when they’re wasn’t any write ups or help. I’ll hear swap the the crank don’t swap the crank use the ls belts no use the crv belts. Just trying to get a straight answer but of course I could just wing it.
Old Mar 12, 2019 | 08:54 PM
Measuring for the belt you need isn't winging it. It's doing what you need to get the right size belt instead of waiting around for someone else to come give you the answer.
Old Mar 12, 2019 | 09:37 PM
10 Year Member
*Most people* just swap over the B18 crank pulley when they do B20 swaps. The part numbers for the B20 crankshaft and connecting rods are exactly the same as the part numbers for the B18 crankshaft and connecting rods, the differences in the rotating assembly are only in the marginally larger pistons.
There's also the small "issue" of the accessories being overdriven with the B20 pulley.
At the end of the day, it doesn't really matter which one you use.
Old Mar 13, 2019 | 12:23 AM
bigjon1378's Avatar
WOW! i just realized this thread is 6 YEARS old
Old Mar 13, 2019 | 06:56 AM
davidg305's Avatar
if I were to swap over the b18 crank would I just make it line up the cranks exactly were I took it off?
Old Mar 13, 2019 | 07:01 AM
davidg305's Avatar
buying a couple different belts isn’t winging it? I guess an educated guess is the proper term. Forums are made for the simple reason of getting answers to questions you don’t know bud. No ones putting a gun to your head and making you reply. Thanks for your help!
vgsr
Dec 16, 2013 04:38 AM
JJtegfan14
May 26, 2009 01:27 PM
Danal976
Aug 3, 2008 05:37 PM
treyh0lla
Jun 28, 2006 09:22 PM
600_Double_R
May 28, 2006 09:52 AM
