knuckle re-assembly question
Old Jan 15, 2013 | 06:23 PM
tegn00b's Avatar
Default knuckle re-assembly question
Hi, in the process of replacing a wheel bearing, I took off the knuckle from the arm attaching it to the frame. Now that I'm back to re-attaching it, I have found that there's nothing to secure the top of the bolt to and that when i try to screw the nut on from the bottom, the whole thing just rotates instead of the nut screwing on while the bolt is stationary. There's a boot between the knuckle arm and the mount that goes to the frame. I can't get a needle nose or a vice grip in there enough to hold it steady. How can i reattach this? 93 integra ls
Old Jan 15, 2013 | 06:33 PM
teggy!'s Avatar
Default Re: knuckle re-assembly question
is there a hole in the bolt for a cotter pin? try wiggling it and getting the bushing to lean on the bolt while you are tightening the nut
Old Jan 15, 2013 | 08:23 PM
IN VTEC's Avatar
Tap the castle nut to clean up the threads.
When you re-install the knuckle and are ready to tighten the upper castle nut, jack up the LCA to clamp the ball joint until you can tighten the nut to spec.
twinturbo57
Nov 23, 2014 11:06 PM
dtran002
Jul 15, 2010 07:13 PM
g2man
Nov 29, 2003 02:30 AM
g2man
Nov 27, 2003 09:53 PM
SC0TT
Jul 23, 2003 05:21 PM
