98 integra ls with 94 gsr swap wiring question
Old Jan 15, 2013 | 06:14 PM
killerB16A's Avatar
Default 98 integra ls with 94 gsr swap wiring question
I just got the car. I didn't do the swap.
on the passenger side shock tower there are 4 plugs. the 4th plug is just 2 wires. there is a 2 wire plug on the chassis wiring and same on the engine wire harness. they look very similar but don't plug into each other. can any one tell me what they are?
I have been searching for about an hour and cant find anything.
Old Jan 15, 2013 | 06:41 PM
teggy!'s Avatar
Default Re: 98 integra ls with 94 gsr swap wiring question
is your vtec wired up? 98 is obd2 and 94 is obd1, so you may no longer need the sensors that the plug connects to.
Old Jan 15, 2013 | 07:23 PM
killerB16A's Avatar
yes my vtec works and engine runs great! but I have a couple check engine lights. code 23 and code 41. heat wire o2 sensor and knock sensor. there isn't a o2 sensor befor the cat. I know this isn't rite. im putting one in. but im confused on the knock sensor. its there and wired up. is the car wire harness pined the same for knock sensor?
Old Jan 15, 2013 | 07:24 PM
killerB16A's Avatar
is there a way to bypass the knock sensor? like ground it out or something?
Old Jan 15, 2013 | 07:52 PM
GagnarTheUnruly's Avatar
If you don't have to worry about OBD checks you can replace the ECU with one that isn't wired for knock detection. It'll need to be chipped with a correct basemap or it'll need an emulator like Hondata or Neptune. Otherwise I'm not sure how you can make the ECU happy unless you connect the knock sensor correctly.
Old Jan 15, 2013 | 08:02 PM
killerB16A's Avatar
I keep reading that if the knock sensor light is on vtec wont work. but clearly mine is working. can anyone explain this?
Old Jan 15, 2013 | 09:06 PM
teggy!'s Avatar
are you running a oem gsr manifold? they had secondary butterflys in them and you may be hearing that and mistaking it for vtec. what ecu are you running it with?
Old Jan 16, 2013 | 05:27 AM
too_slammed's Avatar
my bud die swapped his supercharge GSR into a 2000 Si from a 94? hatch; it was obd1 to obd2 and with the harness there was i believe 2 extra sets of wires that just hung around. werent used for anything so we just tucked them away.
Old Jan 16, 2013 | 05:42 AM
killerB16A's Avatar
I'm running a P72 OBD1 with jumper harness. Engine is stock.
Old Jan 16, 2013 | 10:20 AM
teggy!'s Avatar
then you should be fine because your obd2 harness is still there but the obd1 ecu will just ignore the unneeded plugs. just leave your harness uncut.
Posted from Honda-tech.com App for Android
Old Jan 16, 2013 | 10:40 AM
cvcrcr99's Avatar
The Integra I have was Auto and has that 4th connector on the shock tower with two wires on it. Was your converted to manual? The plug is no longer being used on my set up as I converted to MT and used a MT harness
jdm_sai
Jul 18, 2010 06:05 AM
beginmyhonda
Jul 29, 2009 02:14 PM
phanatic
May 18, 2007 02:21 PM
98civic94gsr
Dec 28, 2004 06:42 PM
DanielLaruso
20
Apr 7, 2003 08:36 PM
