D16 BSFC Charts?
Old Jan 15, 2013 | 08:33 AM
Sven7's Avatar
Icon2 D16 BSFC Charts?
Hi all, first post.
I recently bought a Civic with a D16Y7 as a daily/fun car/hypermiler. I have been searching around but haven't found a brake specific fuel consumption chart. BSFC charts help you accelerate most efficiently and in conjunction with coasting and other techniques can give you much better fuel economy than the EPA suggests.
Here is an example of a BSFC chart:
Does anyone know where to find one for my engine?
Thanks!
Old Jan 17, 2013 | 11:43 AM
Sven7's Avatar
Default Re: D16 BSFC Charts?
Nothing huh.
Old Jan 17, 2013 | 10:41 PM
nanjay's Avatar
never knew.... learned something new today... in for the info
Old Jan 22, 2013 | 02:58 PM
Sven7's Avatar
One last bump. Bueller?
Old Jan 22, 2013 | 04:35 PM
PabloM's Avatar
wtf is this
Old Jan 23, 2013 | 09:13 AM
leoaa777's Avatar
You want MPGs?
Great, start by removing every bit of weight on the car that you don't use. Extra seats, belts, bumper supports, lose some weight yourself unless you are a 98 lb girl, in which case stay that way, nobody likes a fatty.
Keep OEM airbox, header, exhaust. Do preventative maintenance, keep tires inflated properly if not a bit higher than normal. Change wheels for lighter weight ones, lower the car, it helps reduce undercarriage drag. Some kind of front lip helps. Keep the car clean to reduce drag, create some kind of shield for the header and intake. Hotter temps, lower fuel consumption=higher mpgs.
Old Jan 24, 2013 | 09:13 AM
cxserver's Avatar
scanguage . Fun toy.
Old Jan 26, 2013 | 04:04 PM
Sven7's Avatar
Originally Posted by leoaa777
You want MPGs?
I'm a step ahead of ya brah. I got my aero-modded '92 Ford Probe to 41mpg on a 400 mile road trip on one tank of gas (no pulse and glide or engine off coasting or any of that). I suspect the Cd was down in Prius territory. The thing coasted forever.
That said, I'm not stripping the interior out of my Civic. I recently picked up some HX wheels, the PO installed a warm air intake, and I put in 5W-30 oil. The tires are up to 50psi last I checked. I removed the side mirrors and am building a semi-permanent grille block for aero and warm-up. Wheel covers in progress. Later on, LRR tires, rear wheel skirts, fiberglass kammback, air dam, rear belly pan.
I've got some suspension refreshment to do and plan to throw in some cheap coilovers since the Ebay spring sleeves I bought didn't fit over the dampers. It should still be pretty peppy and a fun hypermiler and weekend racer!
Oh yeah, and MPGuino and an injector kill switch. It's still running the stock '92 ECU with OBD0 (It's an EH2)
But if you guys wanted to read about hypermiling you could just go on Ecomodder, so I'll shut up!
Old Jan 26, 2013 | 04:43 PM
cxserver's Avatar
im on there lol. 38.5 mpg b18cr 92 hatch. Funny cuz i was driving it very hard but coasting in nuetral on hills ect.
I could never personaly change the body to look like a canoe just to save fuel lol.
Old Jan 28, 2013 | 01:04 PM
Sven7's Avatar
Yeah, no boat tail for the Civic. It was a fun project but I'll save that shape for a custom built streamliner.
n8guy
10
Apr 12, 2007 09:38 AM
jbs
30
Oct 8, 2004 03:18 AM
EKB18BPR3
Aug 9, 2002 04:40 AM
Raisn_Hell
Mar 28, 2002 12:56 PM
Westrock2000
Nov 11, 2001 10:52 PM
