d15b7 d15b head timing belt problems
Got a 95 civic ex I bought it with the setup that's in it so I only know what I've figured out. the block is a d15b7 the head says p08 which I've been told is d15b. found a receipt for a z6 timing belt in the car. problem I'm having is the belt is way to loose n the car runs like **** basicly like the timing is off (((if I hold the idle up high sounds like it has a two step)) so what belt do I use d15z1 d15b7 d16z6 etc not trying to buy abunch of different belts n I need this fixed asap
hmtcrxsir
Nov 4, 2005 10:07 PM
BauleyCivic
Jul 5, 2003 03:09 PM
