d15b7 d15b head timing belt problems
Got a 95 civic ex I bought it with the setup that's in it so I only know what I've figured out. the block is a d15b7 the head says p08 which I've been told is d15b. found a receipt for a z6 timing belt in the car. problem I'm having is the belt is way to loose n the car runs like **** basicly like the timing is off (((if I hold the idle up high sounds like it has a two step)) so what belt do I use d15z1 d15b7 d16z6 etc not trying to buy abunch of different belts n I need this fixed asap
Re: d15b7 d15b head timing belt problems
From what I've found, the d16z belt is what to use. But to be fair I'm in your boat, bought my car with the same motor and am learning as I go..
hmtcrxsir
11-04-2005 10:07 PM
BauleyCivic
07-05-2003 03:09 PM
