Suspension & Brakes Theory, alignment, spring rates....
94ex brake swap on eg
Old Jan 13, 2013 | 09:36 PM
my74honda's Avatar
Default 94ex brake swap on eg
I am wondering i have the front clip of a 94 civic ex...clearly larger brakes the whats on my eg6 and no i dont have any money for big brake kits and crap this is what i got and you cant beat free the ex had abs my eg does not. if i swap the full crossmember will the rack and pinion of the eg fit on the ex crossmember? are the brake lines different abs vs non abs?? or can i just pull the rotors and calipers??? and last is it worth the trouble to put the sway bar off the ex, on the eg???? thanks for your time and responses
Old Jan 14, 2013 | 04:23 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: 94ex brake swap on eg
The brakes and swaybar should all be a direct fit/bolt on affair. You might have to swap the front LCAs if the existing LCAs don't have accomodations for swaybar bushings.
Brake lines are going to be the same. Just remove the ABS wires as you won't need them. My rear brakes are ABS Integra rear brakes and I certainly don't have ABS on my DX civic.
Front brakes shouldn't require anything outside of a knuckle swap. You certainly don't need to swap the whole crossmember or the rack/pinion.
Unseen Racer
19
Jan 30, 2009 03:50 PM
civicseth
Jan 4, 2007 10:47 PM
NoLipRacen
Jul 6, 2003 01:37 PM
jovial111
Dec 20, 2002 01:47 PM
