Please help
Hi all,i comd from hk,my car is 99 accord CF4 sir-t,i got the wire obd2b to obd1,its just plug and play normally?Anything i need to do,i read alot of post here,still dizzy,please help.Thanks alot
So don't post?
The user has a CF4 Accord which isn't USDM. He has a conversion harness from OBDIIb to OBDI, most likely so that he can run an ECU capable of being tuned. He is clearly asking if there is any additional work that's needed to get the OBDI ECU to work properly on his system.
OP, if you've purchased a complete conversion harness for the ECU you should not need to replace the distributor. You will need a compatible ECU with at least a basemap for your motor or one that will run your motor (You've got an H22 of sorts? So the JDM P13 would likely work)
